is this what your MAF looks like.... - Mustang Evolution
Old 02-23-2005, 06:40 AM   #1
project232's Avatar
Send a message via AIM to project232
Exclamation is this what your MAF looks like....
this is a pic of my MAF/Airbox on my 2000 mustang V6 , i went on ebay to buy a cold air intake but how would i use the cold air intake with this MAF ? is this what your MAF looks like on ur 2000 stang?
http://johnson-performance.com/musta...es/mustang.jpg
http://www.generationblueoval.com/GBO/GBOwebbanner.jpg
2000 Ford Mustang V6
mods listed on Johnson-performance.com
project232 is offline   Reply With Quote
Old 02-23-2005, 06:50 AM   #2
slvr2000stang's Avatar
The MAF itself is inside the airbox assembly.
To use any cold air kit you need to remove it.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 02-23-2005, 07:07 AM   #3
project232's Avatar
how do i remove it? cut it out?
Old 02-23-2005, 08:16 AM   #4
RGR
Send a message via AIM to RGR
I believe it unbolts.
The good CAI kits will have the proper flange to
bolt to the MAF.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 02-23-2005, 08:19 AM   #5
This is the actual MAF taken from my 2002.
The sensor you will need is on the other side of that plastic thing in the center. It all comes apart pretty easily, I got it that far with just a screwdriver to pry plastic off plastic.
Old 02-23-2005, 09:00 AM   #6
you have to dissasemble the airbox to get it out.
Old 02-23-2005, 10:18 AM   #7
Send a message via AIM to NJStang86
It's fairly simple to do...
If you want, I can give you some directions that was included with my Densecharger system.
-Frank-
http://home.earthlink.net/~riz3742/sig2.jpg
2003 Ford Mustang Dark Shadow Gray Coupe - 15.616 @ 87.24 (work in progress)
NJStang86 is offline   Reply With Quote
Old 02-23-2005, 11:12 AM   #8
http://v6stangs.com/index.php?page=h..._cai/index.php
Old 02-23-2005, 11:56 AM   #9
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Thank you Brent.
Also read the CAI article. It will help you with all your Induction questions.
http://www.v6stangs.com/index.php?pa.../cai/index.php
Rellik is offline   Reply With Quote
Old 02-23-2005, 01:07 PM   #10
project232's Avatar
thanks guys , you all are great!
Old 02-23-2005, 01:17 PM   #11
lol, i had the same problem, i didnt know were my MAF was and i let my intake sit in my garage for a month, then i finally got someone that told me were it was, it took about an hour for the intire break down of the previous intake and putting in the new on, BY MY SELF AT 10 PM WITH A FLASH LIGHT, talk about challaging..... after all that i was so disapointed that i didnt hadnt figured it out sooner, its wonderful !!!!
RedV6Stang03 is offline   Reply With Quote
Old 02-23-2005, 03:37 PM   #12
project232's Avatar
yea i knew where it was but i didnt think my MAF sensor was like the ones the CAI's used . so what i was thinking was i had to buy a new MAF so that i could use a CAI .
Old 02-23-2005, 03:45 PM   #13
Nah just take the stock one out of the housing and use it ont eh cai
Old 02-23-2005, 03:47 PM   #14
if you remove the screw holding the black air intake tube onto teh throttle body, then remove the bolt holding the big air box on to the fender side ( 10mm i belive or 8mm )then teh whole assembly comes out minus unplugging the maf connection of course.
then if you look around the box you will see it held on with little clips or what not, if you push in on them you can work your way around the air box and it will eventually seperate, then once it is you can see the maf clearly, it is held on with 4 bolts, remove those, go easy on them they are kind of hard to get off some times, remove teh bolts NOT the studs.
once that is off pull the maff off make sure to keep the maf screen in tact, you need to make sure its installed on the cai when you instal it with the maf.
pull the electric wires though the hole, by pushing out the rubbing stopper to get all the wires free of the air box.
then you just bolt her up to the cai, the hardest part of the cai install is getting the air box on, the best way to do it is not stick the pipe quite so far into the fender well hole, just a little bit so you can manuver the air filter over it then push it on into the filter until its aligned right and thats really it. of course bolt her down god and maek sure to plug hte maf back in whe you are done, else you will get alot of black smoke from the exhaust....
MAF bsmith782 1996-2004 Mustang GT 12 01-30-2007 04:07 PM
90MM MAF DarkShadow Mustang Parts for Sale and Wanted 9 11-29-2006 10:11 PM
MAF gone bad powerhungry966 Pre-2005 V6 Mustang 5 01-24-2006 12:07 PM
do i need an aftermarket MAF? I_luv_HP&trq Pre-2005 V6 Mustang 8 08-02-2005 08:14 PM
Maf ? FloMasta24 Pre-2005 V6 Mustang 8 02-24-2005 06:07 PM
08:58 PM
