Will this cut springs? - Mustang Evolution
Old 02-23-2005, 03:12 PM   #1
Stangthang's Avatar
Can you use a rotary cutoff wheel ? or will it heat it up too much?
Stangthang is offline   Reply With Quote
Old 02-23-2005, 04:06 PM   #2
i cut mine with a cut off wheel, they dont get very off, if you think they are just cut a bit and let em cool.
Old 02-23-2005, 11:14 PM   #3
fastmustangs1's Avatar
Thumbs down
It will work but I would not cut springs really. Just go and get a set that are made to be lowered. You might run into problems done the road so that is not the best way to do it.
Matt
fastmustangs1 is offline   Reply With Quote
Old 02-23-2005, 11:21 PM   #4
Matt
i belive he is gonna cut c-spings. c-springs have whats called a dead coil, this coil is made to be cut without changing the spring rate
Old 02-24-2005, 03:29 AM   #5
Stangthang's Avatar
yes it is too cut the dead coil of c-springs
Old 02-27-2005, 09:31 PM   #6
Ponycarman's Avatar
I used my table saw with a metal cut off wheel. Took about 20 seconds each and then a dump into a bucket of water.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 02-28-2005, 04:48 PM   #7
just about anything will they are not that tuff
Old 02-28-2005, 07:01 PM   #8
Stangthang's Avatar
I was worried if the heat from a chop saw blade would screw up the spring.
I ended up not cutting at all at least for now.
but thanks.
Cut Away Mustang Brent Pictures and Videos 11 07-06-2007 10:46 PM
where could i cut? a00v6stang Pre-2005 V6 Mustang 13 12-27-2005 10:31 AM
where to cut the springs? I_luv_HP&trq Pre-2005 V6 Mustang 6 11-15-2005 10:16 AM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 03:57 PM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 12:13 AM
» Members Mustangs
Frodo
115tang
Kandi
99ford
Add your Mustang
03:08 AM
