braking tech - Mustang Evolution
Old 02-23-2005, 08:39 PM   #1
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
braking tech
i think this is mostly pref. then any thing else but i fig id ask in there, when my dad taught me to drive a manual he taught me to down shift slowly releasing the clutch with no gas to throw up the RPMS and slow the car coming in to a stop. does any one else do this? and what do you do, now i just throw it in to nuteral and just apply the brakes. is that bad for the car?thanks
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 02-23-2005, 08:44 PM   #2
timpryor's Avatar
when i do drive a std car thats what i do
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 02-23-2005, 08:50 PM   #3
fast64's Avatar
i usually do what your dad told you to do, just to slow down brake wear.
GO BRAVES
Old 02-23-2005, 08:54 PM   #4
is it bad for the clutch, when ever i do it i feel like im hurting the car. well the clutch
Delta Sigma Phi
www.DeltaArmsCo.com
Old 02-24-2005, 09:37 AM   #5
Ponycarman's Avatar
I always down shift when slowing, unless it's an emergency stop or something. The key to limiting clutch wear is to match engine speed whne down shifting, in other words bring the engine rpm up to match when going to a lower gear then allow engine braking to work. Letting the clutch bring the engine up to speed does wear it a touch.
Changing brakes is easier and cheaper than a clutch job.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 02-24-2005, 10:07 AM   #6
I engine brake when driving a manual. Hell, I do it in my car, get to about 35 and throw my auto in second to slow me down, trying to save my brakes after getting all 4 rotors turned last week.
Old 02-24-2005, 01:34 PM   #7
its much better for the car to use the brakes, i put her in neutral and slow down with the brake, brakes are much cheaper to replace than a clutch.
Old 02-24-2005, 10:02 PM   #8
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I usually only engine brake when I have to decellerate very quickly, Let out the clutch out slow in 2nd or 3rd and ride the brake. That way the rear wheels are slowing you down more and the front wheels are still doing their braking. Also you can use the brake and engine braking to slowdown and turn at the same time. I do it a lot in autocross. The front brakes do 70% or so of your stopping power, but if your rears are slowing down too, that helps keep the weight transfer down so you're not overloading your front tires.
As far as normal street driving goes? I just push in the clutch and use the brakes to stop.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 02-25-2005, 01:26 AM   #9
Tbird232ci's Avatar
it depends on the day and how im driving
a typical day, ill downshift a few times, ill never downshift into first, which isnt the smart thing to do anyways
on the lazy day, clutch in, throw it in nuetal, and get on the brakes
in the twisties, its all about the downshift
Old 02-25-2005, 08:33 AM   #10
thanks guys, i think ill stick to the clutch in and brake for awhile until im really comfortable with it. thanks all.
Delta Sigma Phi
www.DeltaArmsCo.com
Old 02-25-2005, 03:44 PM   #11
Thomas91169's Avatar
the key to donshifting during breaking is to do it fast enough to where the rpm's hardly drop at all.
or you could do whats called "rev matching" where when you put in the clutch you also blip the throttle and change to the higher gear, so when you let out the clutch it engages and its already at the rpm it would engage at if you just let it out and had to climb to that rpm. thats when you get more comfortable though.
just wait till you get into 'heel toe shifting" boy thats fun stuff.
-Thomas-
Old 02-25-2005, 03:46 PM   #12
its easy to down shift smoothly if you have any skill wiht a manual but its still not good for the life of the clutch, just use the brake.
Braking wiarumas General Car Discussion 10 07-02-2008 01:48 PM
weak braking greenpony02 Pre-2005 V6 Mustang 9 08-08-2005 07:04 PM
questions about braking charkelly9 Pre-2005 V6 Mustang 2 03-28-2005 02:12 PM
Braking issues fastmustangs1 Pre-2005 V6 Mustang 3 10-10-2004 10:54 PM
curiosity question about braking stangracer Pre-2005 V6 Mustang 3 02-17-2004 12:30 PM
04:46 PM
