Springs installed! - Mustang Evolution
Old 02-27-2005, 02:37 PM   #1
Stangthang's Avatar
Springs installed!
This was my first time doing it, I put on C-springs and Mach1 S/S
Im so glad I did not pay somebody to do it. They
wanted $350.00, I did it by myself,with air, it took about 3 1/2 hours it was pretty easy just takes time.
It dropped pretty evenly for not cutting anything, only 1 inch all around
The ride is great I hardly notice any harsher ride, a little stiffer but real nice, just wish it was a little lower.
Anyway Tommorow my rims will be here and then Ill put up some pics.
Stangthang is offline   Reply With Quote
Old 02-27-2005, 04:04 PM   #2
great, its a real; easy procedure
Old 02-27-2005, 05:11 PM   #3
remove the top front isolator and cut the rear dead coil you should see 1.25 to 1.3 all around
Old 02-27-2005, 05:32 PM   #4
Stangthang's Avatar
Im afraid of squeaks and creaks, doesnt that happen when you remove a isolator?
Old 02-27-2005, 05:45 PM   #5
Monkey's Avatar
it can. Just wait until the next time you install springs. I have gotten it down to where I can install springs in 45min now.
Old 02-27-2005, 06:38 PM   #6
the front wont squeek but the rear will so DO NOT remove the rear, only the top front.
Old 02-27-2005, 07:22 PM   #7
Stangthang's Avatar
How long should I wait to get an alignment? for the springs too settle?
Old 02-27-2005, 08:54 PM   #8
fastmustangs1's Avatar
How was the drive after you did the install. My suspension is real stiff but damn it handles so much better than the stock stuff. Next for me is the Panhard Bar and maybe the Evolution Motorsports Tri-Link Kit.
Matt
fastmustangs1 is offline   Reply With Quote
Old 02-27-2005, 09:13 PM   #9
500 miles on the springs then get a alignment
Old 02-27-2005, 09:18 PM   #10
yep, and you should not have a problem getting aligned with that drop
Old 02-28-2005, 04:50 PM   #11
My c springs didnt settle one bit... dont look for yours to either, maybe in the rear which wont affect the alignment, either way wait 500 miles to be sure, but i doubt it will matter much at all.... and even with an alignment on Cs i still wore on the inside (wider tires perhaps) even though the specs said i was with in stock tolerances... which do wear on the inside.... if it wears bad just get a set of GOOD cc plates.
Pics(Lowering Springs Installed) Reaperstang Mustang Audio & Video 13 12-21-2006 12:49 PM
Installed the springs yesterday heres a few pics SVT_99_Cobra Pictures and Videos 12 07-08-2005 09:32 AM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 03:57 PM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 12:13 AM
installed 4cyl front springs tire The Bar 4 03-24-2004 07:32 AM
03:22 PM
