Emissions Test Failed - Mustang Evolution
Old 03-03-2005, 07:11 AM   #1
OK, here's a strange one. I have a 96 V6 Stang that has 155,000 miles. I have no problems with the car in the past two years of owning it. I took the car for an emissions test and it FAILED. The Check Engine light has never displayed and the car has shown no sign failure. The code description that was given is "Cylinder 2 Misfire".
How can I erase the code and secondly, would a simple tune-up and change of spark plugs fix the problem.
Let me know!
robert0803 is offline   Reply With Quote
Old 03-03-2005, 08:06 AM   #2
Ah..poor emissions tests....
I'd do a tune up and change spark plugs and see if that makes a difference first.
Old 03-03-2005, 12:01 PM   #3
How about erasing the codes??
Old 03-03-2005, 12:52 PM   #4
I liek gramer
WhiteStang99's Avatar
try disconnecting your battery for about 5 minutes, then reconnecting it. I dunno if that will help with your emmissions test though.
Old 03-03-2005, 11:08 PM   #5
The problem is if you clear the codes a P1000 code will show up, and they will fail you, thats a tests readiness code, you have to drive about 50 miles so all the tests run and the code goes away.
Does the car run smoothly? its possible to get false misfire codes...but like they said, fresh plugs, fresh wires. Then get the codes read again and see if its there.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Failed Emissions need cats texas96gt 1996-2004 Mustang GT 24 08-08-2008 05:27 PM
Soo...I failed. matthews.stang The Bar 18 04-24-2007 10:14 PM
Failed the gender test PureVenom The Bar 15 12-19-2006 10:03 AM
So my 89 failed inspection... MonteCitan The Bar 18 07-05-2005 10:51 PM
Emissions test Turkish Pre-2005 V6 Mustang 4 07-10-2004 10:36 AM
09:28 AM
