stiff shifting after 3200rpms? - Mustang Evolution
Old 03-04-2005, 10:08 PM   #1
Send a message via AIM to tedness
i've noticed this problem w/ my pony since i got it.
when revving my engine past 3200rpms, like from a light to pass someone etc, i notice that the shifter becomes very hard to move into other gears. has anyone else experienced this or know why it does this?
tedness is offline   Reply With Quote
Old 03-04-2005, 10:15 PM   #2
does this only happen above 3000rpm's?
Old 03-04-2005, 10:16 PM   #3
usually. if i stay in my usual shift bracket of 2500-3000 for daily driving its fine. i can hear the exhaust note die too after the 3000ish marker...i can tell i lose power at that point. (pre-supercharging)
Old 03-04-2005, 10:27 PM   #4
hmmm. could it be a syncro problem?
Old 03-04-2005, 10:59 PM   #5
What exhaust do you have? Gt takeoff's tend to lose sound over 3000 rpm's
Old 03-04-2005, 11:06 PM   #6
nah i have a custom setup w/ flowmaster hushpowers....essentially turbo mufflers
Old 03-04-2005, 11:12 PM   #7
Hm...dunno then.
Old 03-05-2005, 10:47 AM   #8
you should not loose any power at 3k rpms on a modular they dont even peak tq till 4k.... If it was a shifter issue i would try to adjust my clutch you may not be getting enough engagment for the higher rpm shifts, where lower rpms its not a big deal, just take up the slack in the petal to get you more cable to pull on when you push the petal in, that may solve nothing but its a quick check of course.
Old 03-05-2005, 11:46 AM   #9
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
he doesnt have a modular motor. but yea try adn adjust your clutch it could fix the issue.
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 03-19-2005, 11:21 AM   #10
clutch cable / adjustment checking is the first check on the tranny problem road
Stiff Gear Shift. Small Or Big Problem? ecash 1996-2004 Mustang GT 0 03-17-2009 03:51 PM
Stiff gear shift. Small or big problem?? ecash General Mustang Discussion 0 03-17-2009 03:48 PM
Notchy MGW Shifter and Super Stiff King Cobra Clutch Cajun JungleBoy 1979-1995 Mustang GT 14 06-11-2008 02:09 PM
Dont you hate it when people say they will pay for something and stiff you...(inside) SpectorV The Bar 28 10-05-2004 12:07 AM
grinding sound, stiff breaks, and loos of power wile driving blk2kconvstang Pre-2005 V6 Mustang 4 04-05-2004 07:20 AM
10:33 PM
