Build a 3.8? - Mustang Evolution
Old 03-05-2005, 10:57 PM   #1
FloMasta24's Avatar
Send a message via AIM to FloMasta24
Build a 3.8?
I was wondering if any of you guys have rebuilt a 3.8 like just got one to work on(not the one in your car) just build it up and then maybe put it in your car. How much do you think it would cost to do something like that?
1998 3.8L Mods: CAI, Flowmaster dual exhaust with H-pipe, Black Cobra Style headlights, Racer's Choice short shifter -SOLD!
Now cruising in an '03 Nissan Spec V w/ intake and exhaust-hell yeh
Originally Posted by Seph
vday is like an srt4, at first it sounds good and in the long run it sucks
FloMasta24 is offline   Reply With Quote
Old 03-05-2005, 11:02 PM   #2
In the process of doing that now.
It all depends on what you want to do as to how much it will cost
Old 03-05-2005, 11:06 PM   #3
Kiljosh's Avatar
Well figure....
Block w/ crank rods and pistons
- all new say around 2 or 3 grand
-SC block maybe 800-1100 or less depending on its condition
Heads
-stockers maybe 400 or so?? Im not sure
-RPM or SSX 900 or so
Cam
-200 ballpark
Intakes
-Stock maybe 200 for both
-RPM or SSX maybe 400 for both?
Oil pan
-deep sump maybe 300?
Thats basics you can reuse the rest, but thats what you would want to upgrade. You could always build a 4.2 instead, but I know nothing about them Then you need to get new lines, plugs, gaskets, injectors, wiring, motor mounts, or little stuff people always forget about. Might be able to reuse old stuff.
Its expensive
Old 03-05-2005, 11:23 PM   #4
Monkey's Avatar
you're looking at a few dollars to get a head/cam/intake setup with good roller rockers and stuff. Install if expensive on heads and cam unless you know what you're doing to install them yourself.
Old 03-05-2005, 11:52 PM   #5
Kiljosh's Avatar
'03 3.8 Engine and 4R70W trans
That dude's selling an engine for 700 if your serious about it.
Old 03-05-2005, 11:58 PM   #6
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I'm selling parts from a 4.2 that will work for you. Look for it in the powertrain section of the classifieds.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 03-06-2005, 09:48 PM   #7
FloMasta24's Avatar
I know how to work on engines...im in the process of helping a buddy of mine rebuild a 350(going in his TA its gonna be mean)and i can install it and everything at shop class.
Old 03-07-2005, 07:32 AM   #8
RGR
Send a message via AIM to RGR
LMK if you need a cam, I've designed some of the most successful V6 cams
going, and now I have a new lineup of grinders and springs, they really KILL!
Rob and I can help you select parts, and of course Rob sells them too.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
N/A build alcarter4.0 Pre-2005 V6 Mustang 6 06-10-2009 03:33 PM
My turbo build up! VCS_SSSTANG Pre-2005 V6 Mustang 19 02-27-2009 09:47 PM
my turbo build up Kyle Pre-2005 V6 Mustang 71 08-01-2008 11:07 PM
New Computer Build Up! Seph The Bar 22 09-26-2007 02:08 AM
build me a system Rellik Mustang Audio & Video 11 10-20-2003 11:42 AM
11:45 PM
