Advancing the Timing - Mustang Evolution
Old 03-06-2005, 12:52 AM   #1
Kiljosh's Avatar
I have heard there was a way to advance the timing on our engines by yourself since noone seems to make a timing adjuster for our cars. Has anyone had experience with doing this before?
Heres an article from over at v6power http://v6power.net/forum/viewtopic.p...433b0b233fde1f
Old 03-06-2005, 01:01 AM   #2
If you advance your timing too much..it could lead to detonation. Which is not what you want to do.
Old 03-06-2005, 06:44 PM   #3
97Stallion's Avatar
You don't want to mess with that man. Timing should only be messed with in the computer. If you can get a hold of a tuner that uses SCT software, he can get inside your computer and change the timing there. Also, even though they said it on V6Power, but they seemed confused, each tooth is 10* so if you did move it 1 tooth, that would be 10* which is WAY too much.
Living one day at a time!
Old 03-07-2005, 07:29 AM   #4
RGR
Send a message via AIM to RGR
Actually, I was in on the early work with that, Electricat and I talked
alot about that on the phone, and it is an OK way to do it. You can't get
even close to advancing it one tooth, the limitations are much less than that.
It needs further testing, and I thnk it would be a good cheap product to
make (if feasible) for the guys wanting a bit more advance. Maybe an
adapter plate and a fine-tuning adjustment screw, for better infinite
timing adjustments. It would advance the whole curve, adding for example
2* at all RPM's.
Rob, I believe your EEC tuner can read spark timing, we could make one and
have you read it and test it. Nice new product for RDM, don't you think?
If it is fully worked out that is.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-07-2005, 10:41 AM   #5
there are getto things you could do but they are all worthless
Help with spark timing Rawdawg440 1996-2004 Mustang GT 2 07-20-2010 12:06 PM
Timing is off!!!! ballajb 1979-1995 Mustang GT 2 10-28-2009 02:09 PM
TIMING HELP!?!? timeformiller44 1996-2004 Mustang GT 2 04-27-2009 10:05 AM
Q about setting timing Z-EATER General Car Discussion 1 04-04-2008 08:03 AM
timing problems on 94 3.8 eagle05 Pre-2005 V6 Mustang 7 11-26-2007 07:00 AM
06:50 AM
