will a t45 bolt inplace of t5? - Mustang Evolution
Old 03-06-2005, 06:14 PM   #1
Send a message via AIM to tedness
if i were to get a t-45 to replace my sticking tranny would it bolt right up? or do i need to do some modification to the rear end?
tedness is offline   Reply With Quote
Old 03-06-2005, 06:18 PM   #2
We have a tech section on the site ya know
Old 03-06-2005, 06:19 PM   #3
ah yes...forgot about that
Old 03-06-2005, 07:56 PM   #4
so i guess no one knows lol
Old 03-06-2005, 10:20 PM   #5
im pretty sure some mods will be necasary since they dont use the same clutches. also you would need a modified drive shaft, i suggest just getting a g-force t-5.
Old 03-10-2005, 05:05 PM   #6
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
the T45 bolts to a mod motor. We don't have one of those, so you'd need to build an adapter plate and...yeah, it'd be rough.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 03-19-2005, 11:11 AM   #7
it wont work for many reasons, one being the bellhousing wont line up with the motor, and the stock t-45 bellhousing holds the tranny to it from INSIDE the bellhousing making it a PAIN to slide the trans out....
Will a t45 fit on my v6? What bellhousing? Kiljosh Pre-2005 V6 Mustang 7 07-28-2007 01:18 PM
Almost brand new Tri-Ax T5/T45 Matt@StangMods Mustang Parts for Sale and Wanted 2 09-04-2005 05:32 PM
T5 or T45? Mustang414 Pre-2005 V6 Mustang 6 04-24-2005 10:23 AM
t45 tranny noise? afrankart 1996-2004 Mustang GT 5 06-08-2004 04:33 PM
10:48 AM
