Intake Manifold 2 - Mustang Evolution
Old 03-06-2005, 08:06 PM   #1
99'sleeper's Avatar
Region: Delaware
Intake Manifold 2
wat does porting the upper and lower intake manifolds really do? and wat real HP will i gain by doin it?
99'sleeper is offline   Reply With Quote
Old 03-06-2005, 08:09 PM   #2
97Stallion's Avatar
Well since you have a 99, you have split port intakes which fromt he factory flow extremely well. It's hard to give hard numbers, but you can pick up about 10 hp from porting the intakes. When you port them, what you do is remove material from the inside to allow for more air to flow through them. Basically think of bottles one is 20 oz and the other 1 liter. What one holds more air? The 1 liter one. Don't follow this motto to the "T" but the basic rule of hp is more air = more hp.
Living one day at a time!
Old 03-06-2005, 08:15 PM   #3
slvr2000stang's Avatar
They flow well for a fairly stock setup. Adding bolt-ons they are good, after that they need help.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 03-07-2005, 05:50 AM   #4
99'sleeper's Avatar
Region: Delaware
ya i have cold air intake and a t-body w/spacer sofar. thnk guys for ur replys
Old 03-07-2005, 06:29 AM   #5
RGR
Send a message via AIM to RGR
When I did the first set in April 1999, the guy dynoed it and
the gains were +13 RWHP and +16 RWTQ, but I've done lots
of porting and beginners usually do not know what to do.
But it is worth doing, the porting I did was the only mod tested,
and it was simply the intakes, nothing else. On a totally stock motor.
They flow pretty well, but the gains are from the smoother flow
and less heat tansfer from the interior to the incoming air.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
New Intake Manifold! Chick Nasty 1996-2004 Mustang GT 21 08-12-2010 03:15 PM
intake manifold? blackonblack Pre-2005 V6 Mustang 10 01-07-2010 07:49 PM
intake manifold Senorjizzy Pre-2005 V6 Mustang 1 08-30-2009 01:20 AM
Intake manifold ridenmystang 1996-2004 Mustang GT 9 04-23-2007 09:45 PM
95 Intake manifold. Calston31 Pre-2005 V6 Mustang 6 12-05-2004 05:42 AM
03:41 PM
