SPI upper porting Q. cut&weld? - Mustang Evolution
Old 03-07-2005, 09:47 PM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I don't think that you can fully port a split port intake because you can't get all the way down the long runners. Would cutting it, porting it and welding it back together work, like they do on the single port intakes?
That and would it be worth doing?
Just wondering
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 03-08-2005, 05:34 AM   #2
Danger Dude's Avatar
Actually I thought RGR and Pete were using a special honing technique to port split ports. Maybe I am wrong but that is what i thought.
Robert or Pete chime in anytime and help us out on this!!
Old 03-08-2005, 07:12 AM   #3
RGR
Send a message via AIM to RGR
I do have some special techniques.
I have a new flex-honing tool that helps alot in the
long runners, and some techniques that get a better
plenum finish with slight enlargement. But the plenum
walls are so thin that you can't enalrge much! Best
to just shoot for a better interior surface finish.
I can't tell you much, I need to get some patents
and still working on the P-H.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-08-2005, 05:16 PM   #4
Just wondering
I has a cut and welded upper from Tom Y. before I bought the SSX SPI intake It worked well I made 434 RWHP with it on there.
GT-Eater is offline   Reply With Quote
Old 03-08-2005, 05:49 PM   #5
ive seen your car all over the net :worship:
Old 03-08-2005, 05:51 PM   #6
Thanks man I appreciate that .
Old 03-08-2005, 06:06 PM   #7
:worship: I hope that one day my v6 can be like yours
coolstang is offline   Reply With Quote
Old 03-08-2005, 06:30 PM   #8
Hey GT eater..ya live in Jackson huh...hm...I have next week off to do nothing...how about meeting up somewhere lol
Old 03-08-2005, 08:03 PM   #9
RGR
Sweet!
How you doing GT-Eater? Did you ever break 500 RWHP?
Old 03-08-2005, 08:08 PM   #10
Originally Posted by RGR
Sweet!
Will by next week looking at 550 RWHP
Old 03-08-2005, 08:10 PM   #11
Got any pics of this killer?
Old 03-08-2005, 08:12 PM   #12
Hey LowFlyn Yeah I see your in Mississippi also. I will be at the Southern
V6 Challenge an Alabama .But I'm sure we could hook up some time .I go to
Hattisburg and Lena alot so we will definately have to meet up.
Old 03-08-2005, 08:14 PM   #13
I trying to come to that meet. I'm in Hattiesburg a few weeks out of the year. But I guess if nothing else I'll see ya at the meet. Will hopefully be leaving my apt here in Starkville sometime friday.
Old 03-08-2005, 08:16 PM   #14
Cool hope you can make it ,it's going to be a cool event .
Old 03-08-2005, 08:20 PM   #15
RGR
Cool! Hope you make it, is that with the same cam and more boost?
I got a used cam for a guy that has a similar combo to yours, it is going
together now. He just wants between 4 and 500 RWHP, it should ge easy.
The cam is pretty close to yours, it's my old single port SC grind from the last
millenium, but after we saw what you made I knew it would work well for SPI.
Dood has an 11# ATI w/IC. Should run well...
Old 03-08-2005, 08:21 PM   #16
RGR
BTW, Welcome to EVO.
Old 03-08-2005, 08:49 PM   #17
T -Trim and a 100 shot for me
Old 03-08-2005, 08:58 PM   #18
RGR
Boost and chemical IC is a nice combo
Did you get the busted piston fixed or was that someone else?
Old 03-08-2005, 09:01 PM   #19
That was Michael Konners
Old 03-08-2005, 09:20 PM   #20
RGR
icic
Old 03-08-2005, 09:43 PM   #21
Oh BTW yeah same cam it's still got some left in it . Next engine Bigger cam
Old 03-08-2005, 09:49 PM   #22
NorwegianMustang's Avatar
Send a message via AIM to NorwegianMustang Send a message via MSN to NorwegianMustang Send a message via Yahoo to NorwegianMustang
I hail you all the way from Norway :worship:
Mods: Magnapacks, BBK X-pipe with cats, BBK CAI, hood struts, KYB Shocks/Struts, Eibach Pro springs, SS Inserts, CDC Light bar, Chrome 17" Bullits with Nitto 555 and N2O with dual purge
NorwegianMustang is offline   Reply With Quote
Old 03-08-2005, 09:52 PM   #23
Wow Thanks ,I'm flattered .
Old 03-08-2005, 09:53 PM   #24
Hehe, I'm ready to see this car. Are you the 02 registered on the planning site?
Old 03-08-2005, 09:54 PM   #25
No I tried to upload you a pic or two but even if I reduce them to thumbnails it would not upload .
shoot me your e-mail and I will send them that way if you want .
Old 03-09-2005, 06:36 AM   #26
Send a message via Yahoo to 98GreenStallion
I have Miks cut and weld upper, Im not really sure if it makes all that big of a difference from the standard ported upper.I guess Ill have an idea after I get rid of the cats.
http://images.cardomain.com/member_i.../402003_35.jpg
Mods: BV heads, cut and weld upper, fully ported lower, 216/225 cam, 1.73 RR's, 60mm TB, 19# injectors, new timing set, 25% UDP, CAI, SCT chip, PCV delete, EGR delete, MAC LT headers, O/R H-pipe, durablack cat-back...
www.rpm-mustangs.com
RDmotorsport
New dyno
193.8rwhp/238.9 rwtq
98GreenStallion is offline   Reply With Quote
Old 03-09-2005, 03:45 PM   #27
Yeah if theres one thing I've learned about my set up is Flow,Flow,Flow
the better the flow the more HP.
Old 03-09-2005, 04:12 PM   #28
RGR
It is a good upgrade, I had a dyno somewhere, if I can find it I will post.
Old 03-09-2005, 04:17 PM   #29
RGR
Yeah, there was a 4.2 that had my old 3.8 SPI cam,
and it made 265/280, when Mik was working on that
setup, it made an extra 32 HP and 30 TQ from porting
the upper intakes heavily. I saw that combo from SSM
that had a much larger cam and made 260/260 but it
looked like to me they were preparing that one for an
SSX upper, due to the huge cam in there. It had a
standard ported upper intake according to the parts list,
so I'm sure that was holding it back especially with the
big ole honkin' cam
Was that Mr Konor?
Porting upper and lower intake stangaroo Pre-2005 V6 Mustang 8 03-09-2010 12:55 PM
FS: Weld Draglites wheels & tires hottcobra Mustang Parts for Sale and Wanted 0 03-27-2009 12:22 PM
P&P Upper & Lower -Spilt Port Herbstang Mustang Parts for Sale and Wanted 11 10-10-2006 09:09 AM
P&P'd upper and lower... DarkShadow Pre-2005 V6 Mustang 16 05-04-2006 10:44 PM
Gauging Interest P&P Upper & Lower Split Port Herbstang Mustang Parts for Sale and Wanted 0 09-22-2005 08:45 AM
09:34 AM
