how do i... - Mustang Evolution
Old 03-09-2005, 09:40 AM   #1
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
how do i...
install anti-lock brakes on my stang? or can i?
i'm tired of getting my car smashed cuz of my brakes locking up
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 03-09-2005, 12:56 PM   #2
Hm...the system is run by computer, so you'll need a computer program put into your car's computer system to run ABS. This will probably end up being very expensive...if it was me I'd learn how to use PMABS (poor man's ABS), in other words just get used to pulsing your brakes at the brink of locking up instead of trying to get an entire brake system.
Old 03-09-2005, 04:13 PM   #3
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
You'd need to install teh abs exciter gears on all four wheels to make it work right, and get all the hardware hooked up to pulse the brakes... I'd stick with non-abs personally. If driven well, they stop MUCH faster than ABS.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 03-09-2005, 04:59 PM   #4
wow were do i start, u would basically need a donor car that has abs, ands swap out the parts and the computer. if you try to find all the part you WILL go crazy.
Old 03-09-2005, 06:57 PM   #5
dark's Avatar
well ****
Old 03-19-2005, 11:12 AM   #6
dont lock your brakes up buy cobra brakes and stop alot faster.
07:28 AM
