stroker? - Mustang Evolution
Old 06-15-2009, 09:00 PM   #1
stroker?
i have an 07 mustang could anyone tell me what a stroker kit is and where i can have it done/buy one and how much hp i can make with it along with some headers and dual exaust.
Skyler1991 is offline   Reply With Quote
Old 06-15-2009, 10:06 PM   #2
Re: stroker?
When you stroke an engine your basically increasing the travel of the pistons. They move further up and down in the cylinder, resulting in more torque and larger displacement. This is done by replacing the crankshaft, along with the rest of the bottom end ~ crankshaft/main/rod bearings, piston rings, connecting rods
Tom Morana and Moranav6racing have a stroker kit available for the 4L OHC in your mustang, I think they start around $2500.
I'm not sure about Super Six Motorsports, I know they have 4.0 products, but not sure about stroker kits.
You'll probably see about 20-30 hp and tq from just the kit. You'll notice more torque, but your top end might decrease as you might make less hp. If you upgrade heads, cam, and intake along with the stroker kit all followed up by a good tune, you'll see more hp. You can probably see a 7-10 hp with the headers and the exhaust.
You will probably want to beef up your rearend and some suspension components, as well as brakes to handle the extra power.
Old 06-16-2009, 07:07 AM   #3
Re: stroker?
for an 07 thats nearly new it would be cheaper to sell it and buy a gt if you want more power, you can do it no doubt but just saying it wont be cheap.
Old 06-16-2009, 08:04 AM   #4
Re: stroker?
yea id just get the gt.
tvs supercharger,20 lbs of boost,cti stepped header, cti 3" catless dp,cti 3" catback,79# injectors,ls4 tb,rebel 3" cai, cx raceing heat exchanger ,billet rotated tranny mounts,dss stg 2 axles,spec 3 plus clutch,spec alum flywheel,steel crank,steel rods,hyper. pistons,4.05 1st gear,posi diff.. tuned by auto motion .next week meth and more boost.
fast cobalt is offline   Reply With Quote
Old 06-16-2009, 10:01 AM   #5
Re: stroker?
I didnt mean to say the car is not worth modding, it is, its just if you want 300hp then you will have to spend a good bit of cash to get there. A supercharger or turbocharger will do it and run you around 3-5k depending.
Old 06-16-2009, 10:04 AM   #6
Re: stroker?
turbo kit will be the easyist way to go.
4.2 stroker 3.8boii Pre-2005 V6 Mustang 5 05-26-2010 06:19 PM
want to do a 4.3 stroker Jordan Pre-2005 V6 Mustang 14 03-27-2010 04:57 PM
Stroker engine help trikmit Classic Mustangs 2 11-30-2009 04:30 AM
5.1 Stroker Hp? 67mustang97 1996-2004 Mustang GT 13 01-09-2009 12:57 PM
2.8L stroker Tbird232ci Pre-2005 V6 Mustang 1 01-11-2006 06:42 PM
09:10 PM
