CAI V. UDP - Mustang Evolution
Old 08-03-2003, 03:49 PM   #1
CAI V. UDP
Do you think the money is better spent on CAI first, or UDP?
I have dual exhaust, chip, and K&N filter now.
Thanks
SixSilver is offline   Reply With Quote
Old 08-03-2003, 04:01 PM   #2
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
If you buy a Ebay CAI, they are like 40-70 bucks shipped. So the CAI is cheaper.
But i loved my UD after installation. But I see you have a 2002, UD Pulleys are alot more expensive for your years because the Harmonic Balancer and Pulley is one unit.
So tis 150-200 shipped for a pulley.
Pulley and CAI, are roughly the same HP and TQ gains.
Dont expect any big gains with them.
Rellik is offline   Reply With Quote
Old 08-03-2003, 04:11 PM   #3
tire's Avatar
Send a message via AIM to tire
the underdrive pulley will run you 200-210$ w/ a new belt, so it is more expensive. i don't have CAI because i'm going to get a supercharger. however, it is cheaper for sure.
tire is offline   Reply With Quote
Old 08-03-2003, 04:18 PM   #4
ehh CAI wont see too much of a gain really. Its more of what I call a multiplier mod. The more you add the more it helps (exhaust, p&p, cam, etc. )
UDP will net you a solid gain 8rwhp/8rwtq as it is only there to reduce parasetic loss.
best bet... do both
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 08-03-2003, 05:43 PM   #5
tire's Avatar
if anything, the underdrive crank pulley will be a 'multiplier mod' because it takes whatever the engine makes and takes away a percentage of belt drag loss.
Old 08-03-2003, 07:44 PM   #6
no, parasetic loses are static. Your accessories spin with your crank. so whatever RPM your crankshaft is rotating at, is the same whether you make 1000hp or 100hp
New Hottness
1999 V6 5-speed
Wrecked
Old 08-03-2003, 07:49 PM   #7
Danger Dude's Avatar
The Underdrive pully will be you biggest gain by removing some of the parasitic drag of the waterpump and A/C by slowing it down they will have a bigger impact than the CAI
Old 08-03-2003, 08:34 PM   #8
Send a message via AIM to synister232
i just went on ebay - where are these 40-70 dollar CAI's at???
i saw one brand but it said 96-03 and i heard that 99+ wont work directly with a 94-98
Mike P
http://www.mustangmods.com/data/174/synister_sig03.jpg
1997 Ford Mustang - K&N, MAC U/D Pulleys, Dual 2.5in DynoMAX mufflers, Indiglo Horse, Indiglo Gauges, MTX 300W amp, 2 12"s, and misc interior
synister232 is offline   Reply With Quote
Old 08-03-2003, 08:49 PM   #9
Either way, the gains arent going to be that dramatic.
The UDP is more expensive, the CAI is less expensive. The UDP is a little bit harder to install IMO.
It's your choice. The gains are about the same.
Old 08-03-2003, 09:20 PM   #10
tire's Avatar
i have been under the wrong impression then for a year or more. can someone back this up just to make certain.
thanks stangin99 for the skooling.
Old 08-03-2003, 10:30 PM   #11
actually there is a reduction in parasitic loss with the waterpump that spins in water cause greater resistance with the increase in speed,by reducing that drag by 25 % in rotation speed you reduce resistance in the waterpump. Why do you think drag racers use electric water pumps. Plain and simple
Old 08-04-2003, 06:26 AM   #12
Accessories are all spun by the crank pulley (crankshaft).
So whatever RPM the crank spins at, determines the RPM the accessories spin at. This is why, with a smaller crank pulley, the accessories with their HUGE pulleys, spin slower, ~25% slower.
As your rpm/speed increases, your accessories DO work harder though (waterpump/alternator) so there IS more of a drag on the parts. But remember, your only changing one pulley. So unless your trapping at like 120+ now because of you pulley, the few MPH's you gain in the 1/4 wont add enough strain on the accoessories to notice.
Whether your going 100mph or 10mph, if your cruising at 2000RPM's your accessories are doing the same thing. (basically)
EDIT: I know you talked about elctric waterpumps, but we arent drag cars. These are daily drivers
New Hottness
1999 V6 5-speed
Wrecked
Old 08-04-2003, 08:03 AM   #13
I mentioned electric waterpumps as a example of the drag a waterpump has on a engine and how drag racers see it as enough of a parasitic loss to put on a electric pump
Old 08-04-2003, 08:07 AM   #14
ah ok
New Hottness
1999 V6 5-speed
Wrecked
Old 08-04-2003, 08:10 AM   #15
I do wish someone would come up with a electric water pump that could be applied to a daily driver though
Old 08-04-2003, 08:14 AM   #16
Send a message via AIM to el cheapo
didnt i just post about that??
damn it school, why do you suck so bad??
el cheapo is offline   Reply With Quote
Old 08-04-2003, 08:15 AM   #17
eh..
a friend of mine wants to get a new belt for his 01 GT. He only wants to run it from crank, tensioner, waterpump, alternator.
He doesnt care about power steering for the track (who would) and he really wants to take out his A/C but hes a lazy bastard like me
You could always just drive around with no belt....just make like 1-2 minutes trips at most
New Hottness
1999 V6 5-speed
Wrecked
Old 08-05-2003, 06:25 PM   #18
you get about double the performance gains with a pulley....well not double but near it.
Old 08-08-2003, 10:48 PM   #19
OR_Red98's Avatar
Region: Oregon
Dennis........Retired USAF, Disabled Vet.
http://www.mustangmods.com/data/666/the_stang_005.jpg
Red "98" coupe V6 AT. Saleen boby kit, 18" replica Saleen rims, FMC "C" springs, Mach 1/Tokico shocks/struts, GT sway bars, GT STB, Sequential turn signals, Euro head lights and clear corners, BBK CAI and GT take-off exhaust.
OR_Red98 is offline   Reply With Quote
Old 08-09-2003, 07:38 AM   #20
Old 08-09-2003, 12:26 PM   #21
Old 08-09-2003, 02:33 PM   #22
OR_Red98's Avatar
Region: Oregon
Old 08-09-2003, 03:42 PM   #23
New Hottness
1999 V6 5-speed
Wrecked
Old 08-09-2003, 09:55 PM   #24
cai
afe stage 2 cai or C&L racing cai b's stang 2005-2010 Mustang GT 5 05-20-2010 06:25 PM
fs 99-04 25% udp mustang0386 Mustang Parts for Sale and Wanted 1 03-04-2007 02:48 PM
udp mustang0386 Pre-2005 V6 Mustang 6 12-18-2006 01:02 PM
Bolt On's ~ CAI, UDP, MAF, and window decal DarkShadow Mustang Parts for Sale and Wanted 16 06-22-2006 08:41 AM
WTB: UDP and CAI petrey10 Mustang Parts for Sale and Wanted 1 07-27-2005 09:23 PM
07:04 PM
