Supercharged V6 - Mustang Evolution
Old 06-17-2009, 08:10 PM   #1
Supercharged V6
Is it possible to swap out a normal 3.8 in an 01 for the Supercharged 3.8 that Ford used to put in the Thunderbird and Cougar?
BTW, Noob here. Cool site.
stout33 is offline   Reply With Quote
Old 06-17-2009, 10:07 PM   #2
Re: Supercharged V6
Well, it's certainly isn't impossible, but it's not as simple as bolting right up and going either. I'd take a moment to see where you want to go with the car. Typically on here we'll tell you engine swaps can be done, but aren't as efficient as buying a car with the desired engine in it. But...if upgrading cars is out of the question and if you're hell-bent on doing it and have the mechanical abilities/resources to do 99% of the work, there are some options.
The easiest way is to have the complete engine, along with it you need the ecu, harness, and some supporting stuff.
Many people have done it, but the ones I know of did it to pre 99 v6s. Some guys at allfordmustangs and v6power.net did it on 94/95's(145hp stock) and ended up with 198rwhp . Your 01 has 190 at the crank. You're probably at about 168-170 rwhp give or take manual or auto. Full bolt ons and a good tune and you're pretty close to 198rwhp, just something to keep in mind.
It's up to you, if you have the complete engine and want to do it, go for it, it has been done. But if you're looking at options and are determined to do an engine swap, I would consider a v8 engine swap. Again, the easy way to do this is a donor car...however, the easiest way is to sell your current car and buy a v8.
Old 06-18-2009, 07:17 AM   #3
Re: Supercharged V6
you can swap the entire engine over, but not just the supercharger as they are very different. For the money your MUCH better off doing an M112 supercharger swap onto your car (using an 03/04 stock cobra supercharger and adaptor plate etc) but you have NO intercooler of anytype... so the temps are VERY hot. You could do a standard supercharger or a turbocharger.
Your looking at 3-6k invested for this (for the m112 its around 2-3k) and end results should be between 250-300rwhp with around 8-12psi needed.
Old 06-19-2009, 09:57 PM   #4
RyansQuick6's Avatar
Re: Supercharged V6
To put an M90 on a new edge you'd lose power. You have to run ****ty single port heads for it work.
RyansQuick6 is offline   Reply With Quote
Old 06-20-2009, 12:15 PM   #5
Re: Supercharged V6
^^^Yah, all the guys I've seen do it had 94-98 single ports. I would do either the m112route (which isn't even the best way) or a vortech supercharger.
Old 06-20-2009, 04:52 PM   #6
jimmy_beaner's Avatar
Region: Iowa
Re: Supercharged V6
get a centri, or get the M112 kit... turbos are always nice too
Old 06-22-2009, 02:12 PM   #7
Ninethourpm's Avatar
Re: Supercharged V6
95 SC 230 HP @ 4400 RPM 330 ft/lbs of TQ @ 2500 RPM
LOSS? WHAT LOSS?
Thats 40 more horses and what 100 ft pounds more tq?
While I agree hes better off with a M112 there is no LOSS.
2000 silver 3.8 5 speed,smoke tint,cold air intake,MAC Long tubes, MAC Catted H,MAC GT catback, SCT Livewire w/ Bamachips tune,
17x8Fr 17x9Rr Bullit Wheels More to come......
96 honda magna vf750, K&N, Vance and Hines pipes Rejetted carbs
Ninethourpm is offline   Reply With Quote
Old 06-22-2009, 10:24 PM   #8
Re: Supercharged V6
That's on forged internals, so now why don't you show me.
You lose 40hp just by swapping the heads from the stock 99+ 3.8.
An M90 isn't a bad S/C, it just looks better mounted on a Roush. And even then, I think Roush needs to up their game.
Old 06-23-2009, 03:27 AM   #9
Re: Supercharged V6
forged gains power? and all this time i thought it was to keep your engine from going boom.
Old 06-28-2009, 12:43 AM   #10
2007STANG's Avatar
Region: West Virgina
Re: Supercharged V6
read this http://www.forced4.com/v6project.html not bad for a 6er
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
2007STANG is offline   Reply With Quote
Old 06-28-2009, 02:43 AM   #11
Re: Supercharged V6
uh, yeah, considering what you can do with a forged bottom end. Do you even have a clue what you are talking about?
Old 06-28-2009, 09:42 AM   #12
Re: Supercharged V6
considering the SC has hypereutectic pistons, forged rods and steel crank (not entirly forged)
We are talking about what it does not what it could do if you turned up the boost.
If he put single port heads AND Intake yes he would loose 40 hp BUT were talking heads and supercharger so he would be making 40 more hp than he is now.
Would he gain more just switching to ported heads with bigger valves ,ported intakes and a cam probably.
but no hes not going to end up with 150 hp after the single port heads AND m90 as you are suggesting.
Old 06-29-2009, 07:17 AM   #13
Re: Supercharged V6
building the 3.8 to a 4.2 you can pull 250rwhp or so~ which is more than you will get with that supercoupe engine near stock.
Old 06-29-2009, 05:52 PM   #14
Re: Supercharged V6
if stock i think its more like 210 hp 240 tq
supercharged v6 mustang9403 Pre-2005 V6 Mustang 11 12-12-2008 02:51 PM
Supercharged 6? SeadudeRXP Pre-2005 V6 Mustang 41 10-13-2005 08:08 AM
supercharged v6? stangracer Pre-2005 V6 Mustang 16 11-03-2003 08:45 AM
08:30 AM
