stock mustang cam shaft? - Mustang Evolution
Old 03-12-2005, 02:31 PM   #1
Does anyone know what the a 2000 V6 mustang stock camshaft specs are? i.e-lift, duration, on both exhaust and intake, and what are the stock valve springs rated for lift?
bigpomps is offline   Reply With Quote
Old 03-12-2005, 02:43 PM   #2
I used to know... see if rpm-mustangs.com has em listed
Old 03-12-2005, 02:58 PM   #3
slvr2000stang's Avatar
Cam info:
Here are the specs from stock Mustang and 4.2 truck cams...
96-98 3.8v6s: 184int/202exh (@ .050" lift).
.424/.448" valve lift. 110 Lobe sep, 105 Intake c/l
97-01 4.2v6s: 185int/194exh (@ .050" lift).
.443/.445" valve lift. 112 Lobe sep, 110 Intake c/l
99-01 3.8v6s: 178int/194exh (@ .050" lift).
.427/.446" valve lift. 116 Lobe sep, 111 Intake c/l
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 03-15-2005, 01:02 PM   #4
RGR
Send a message via AIM to RGR
That's the same info I have, and furthermore, the stock springs are
only good for .480" lift. Pretty much the same for all years before it.
All Ford cams (stock) are lame-O
Have you seen our GP? links in my sig...
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
INPUT SHAFT!!! redcobravert 1996-2004 Mustang GT 12 08-23-2009 01:59 PM
Aluminum Drive Shaft? Paincake1 Pre-2005 V6 Mustang 5 01-22-2009 05:41 PM
Cam a stock 5.0 Justin 1979-1995 Mustang GT 63 02-08-2007 09:17 PM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-26-2006 11:15 PM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
11:30 PM
