Which Tuner to Get? - Mustang Evolution
Old 06-18-2009, 04:35 PM   #1
Which Tuner to Get?
I tinker with older Mustangs but don't know too much about the newer computer controlled ones, so I need some help/suggestions.
I have a 2007 V6, while it was under warranty I had a cold air intake and dual exhaust put on. The dealership reprogrammed the computer and it runs great. I now took out the 7.5 and put in an 8.8 with 3.73 gears. I want to get the speedo corrected for the new gears, raise the rev limiter and speed limiter. I checked a couple shops and they want to charge about double what I would pay for a tuner. So I'm thinking about getting a tuner in case I make more changes later.
So I have a few questions about tuners. I've looked a little at the Diablo and SCT. Both show they can make the changes I need. They seem to have preprogramed tunes, are they limited to that or can you make individual adjustments? Also, since I do not have a stock tune currently will the tuners plug in and determine that or would I need to take my computer back to stock first?
thanks for any help or suggestions.
Mom's - 2007 V6, 5 Speed, Dual Exhaust, CAI, 8.8 with 3.73 gears, Stage 2 Clutch
1965 351C Dragcar Restoration in progress,
1966 289 Pony Restoration in progress
Son's - 2003 V6 4.3L Stroker with lots of goodies,
1965 Dragcar in progress,
1965 Restomod in progress
mxw1090 is offline   Reply With Quote
Old 06-18-2009, 07:40 PM   #2
iwannagofast's Avatar
Re: Which Tuner to Get?
one suggestion would be if you plan of adding some real power adders like S/C or T/C find out what your local dyno uses, some only use one some use both
iwannagofast is offline   Reply With Quote
Old 06-18-2009, 10:33 PM   #3
1234's Avatar
I would say SCT.
Old 06-18-2009, 10:53 PM   #4
Whatever you do, don't buy the off the shelf tuners. They suck compared to getting a custom tune done or just tuning it yourself. I would check out VMP Tuning, I've heard they do a good job tuning v6's using SCT.
The tuner will also make the bolt ons like exhaust and CAI more effective, and seriously help your tranny if you're an auto.
Old 06-19-2009, 08:40 AM   #5
any good tuner will make fixing the speedo and rev limiter VERY easy, you just calculate the revolutions per mile and alter them as needed. I good tune (dyno tune) will result in more power as well rather than just a can tune.
Old 06-19-2009, 12:46 PM   #6
Greywolf's Avatar
Region: Nevada
I've got an 07 v6 and I went with SCT. Go to VMP and get ahold of Justin. He did wonder's with mine. I had exhaust and cai when I got it first and have since put the pulley and the 4.10 gears with a tlok and everything's still adjustable with the unit. Even before the gears and pulley it woke her up immediately. Highly recommended as is Justin. he knows his SCT.
2007 V6 Mustang w/ Pony Package. Performance Mods - 2.25 custom aluminum catback exhaust with a Magnaflow muffler, AirRaid cold air intake, drilled and slotted rotor's front and rear, SCT Programmer, Ford Racing Tlok, Motiv 4:10 gears, LFP underdrive pulley
Greywolf is offline   Reply With Quote
tuner upton7 1996-2004 Mustang GT 13 02-21-2010 09:37 AM
Need a Tuner!! jdhog2003 2005-2010 Mustang GT 1 12-15-2009 01:31 AM
Tuner GT773 2005-2010 Mustang GT 12 06-16-2009 03:41 PM
Tuner upton7 1996-2004 Mustang GT 2 05-16-2009 12:56 PM
Why get a tuner? Laser 1996-2004 Mustang GT 10 06-11-2007 08:31 PM
01:31 PM
