Pics of BV head install - Mustang Evolution
Old 03-12-2005, 09:59 PM   #1
Danger Dude's Avatar
Here are pics from todays installations of BV heads, Harland Adj RR's and a matching lower intake.
ID:	7088   Click image for larger version
ID:	7090   Click image for larger version
Old 03-12-2005, 10:17 PM   #2
very cool.
Old 03-13-2005, 12:32 AM   #3
Awsome can't wait till my engine looks like that
Old 03-13-2005, 12:49 AM   #4
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
your engine bay looks awesome corey
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 03-13-2005, 07:32 AM   #5
Send a message via Yahoo to 98GreenStallion
Looks good man... Cant wait to see some numbers on that setup as you and me now have like the same stuff. Is your upper intake a cut and weld or standard ported?
BTW, have fun getting your RR's adjusted properly... Took me like 4 tries! They are still chattery and even kinda loud when the engine warms up... I guess Harland Sharp rockers are just noisy.
The rockers are not making any noise at all. My Upper is cut and welded by RGR !!!!
http://images.cardomain.com/member_i.../402003_35.jpg
Mods: BV heads, cut and weld upper, fully ported lower, 216/225 cam, 1.73 RR's, 60mm TB, 19# injectors, new timing set, 25% UDP, CAI, SCT chip, PCV delete, EGR delete, MAC LT headers, O/R H-pipe, durablack cat-back...
www.rpm-mustangs.com
RDmotorsport
New dyno
193.8rwhp/238.9 rwtq
98GreenStallion is offline   Reply With Quote
Old 03-13-2005, 08:16 AM   #6
slvr2000stang's Avatar
Looks great Corey.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 03-13-2005, 04:37 PM   #7
who did the work for you?
Old 03-13-2005, 04:45 PM   #8
Monkey's Avatar
nice corey. makes me want a new head.
Old 03-13-2005, 04:50 PM   #9
NorwegianMustang's Avatar
Send a message via AIM to NorwegianMustang Send a message via MSN to NorwegianMustang Send a message via Yahoo to NorwegianMustang
Looking good Corey
2 x
Can't wait untill I get some new heads too.
Mods: Magnapacks, BBK X-pipe with cats, BBK CAI, hood struts, KYB Shocks/Struts, Eibach Pro springs, SS Inserts, CDC Light bar, Chrome 17" Bullits with Nitto 555 and N2O with dual purge
NorwegianMustang is offline   Reply With Quote
Old 03-14-2005, 07:39 AM   #10
RGR
Send a message via AIM to RGR
aight dude!
What are your springs good to for lift?
SKiLLeT HeaD RaCiNG needs a new cam!
CLOOOOOONNNGGGGG!!!!
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-14-2005, 08:03 AM   #11
I am not sure but I believe in looking on Mikaels sight they are .540" lift capability conical valve springs for 96-04 3.8s
Old 03-14-2005, 10:08 AM   #12
RGR
Yeah, his machine shop that assembles them uses a different
shim pack and comes out to less IH than I do those same springs
for myself. The seat pressures are high enough without shims unless
you have an SC at pretty stout boost. They do great work, I just
think they do the spring pressures for the heavier older style valves.
Plus you have the 8mm stems, that is a different arrangement and
I have not personally checked that one. I got some here but the
heads need machined to use them and even check the IH's.
Old 03-14-2005, 10:21 AM   #13
RGR
Hey man, you must be at lunch all I get is voicemail
Old 03-14-2005, 10:46 AM   #14
Call me now I am in
Old 03-14-2005, 03:25 PM   #15
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Corey... can I have your car? Please?
Rellik is offline   Reply With Quote
Tow-hook install pics WD-40 2005-2010 Mustang GT 5 02-11-2010 04:45 PM
Yes, turbo install pics... DarkShadow Pre-2005 V6 Mustang 10 05-17-2006 11:10 AM
Updated Pics of my Install Kiljosh Pictures and Videos 0 07-02-2005 04:04 PM
Pics of Brent's 8.8 Install n8r Pre-2005 V6 Mustang 17 07-07-2004 02:32 PM
Some pics of my long tube header install... Junior2561 The Bar 8 02-23-2004 03:29 PM
07:36 PM
