The PRO's of installing a intake spacer on 94-98 V6's - Mustang Evolution
Old 03-14-2005, 02:00 PM   #1
Danger Dude's Avatar
Here is something to consider. If you are building your engine up whether doing heads and cam or just adding roller rockers a phenolic intake spacer is a wise decision.
If you have a intake spacer you do not have to take the upper intake off to get the driver side valve cover off. This will save you time and trouble if you have to go in and readjust rocker arms.
Now saying that there are people on both sides of the usefulness of intake spacers on a V6. I have seen the data and I believe they provide a decent barrier against engine heat transfering to the upper intake. This provides some lower temps in the air charge in the plenum. The actual gains in HP might be small and not worth it to some. But on a purely mechanical level they provide for easy access to the drivers side valve cover.
Just my take on it!!!
Old 03-14-2005, 02:13 PM   #2
ComputerGuy's Avatar
I was looking at a 3/8ths spacer myself
ComputerGuy is offline   Reply With Quote
Old 03-14-2005, 02:53 PM   #3
i wouldnt mess with one... to much hassel for nothing and you may get a leak from it.
Old 03-14-2005, 03:14 PM   #4
You have a 99 which has so many potential holes to leak. But I am confident in my mechanical abilities to install one and not leak!!!!
So that is a moot point
Old 03-14-2005, 03:24 PM   #5
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
I love my 3/8" phenolic spacer. I dont care about the debates, I like it.
I just wish I had saved the jpg of the EE dyno tests... but I believe they're gone forever.
Rellik is offline   Reply With Quote
Old 03-14-2005, 03:26 PM   #6
They are not still on 3.8 or V6power I know they were posted at one time.
Old 03-14-2005, 08:18 PM   #7
RGR
Send a message via AIM to RGR
I agree with Corey, but also if one has a heavily ported upper intake
the spacer may not do anything, or less than an un-ported intake.
I read a very detailed article by David Vizard and he explained heat
transfer in such a way that proves that anything you can do for
reduced heat transfer will help below 3KRPM's give or take. He is
much more well educated than the sceptics and he is right.
I firmly believe though that well-ported uppers pretty much nullify
the spacer's effectiveness. Maybe not 100% but a fully ported
upper has lots less heat transfer due to smoother internal surfaces.
I had a dyno (Josť still does have it) that showed the Stage 3 giving
a nice torque boost up to 2500, dead even after that and gaining again
after 4500 RPM or so. The low end boost must have been due to the
internal polishing, because the runners were shorter and that is supposed
to move the torque curve upward. This was a Stage 1 vs. a Stage 3 dyno.
Vizard states that at RPM ranges above ~3K, the air is not in the intake long
enough for significant heat transfer, and therefore the intake charge heating
is minimized at higher RPM's.
DV rules
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-15-2005, 09:53 AM   #8
I looked for those too.... but couldnt find any.
Old 03-15-2005, 10:20 AM   #9
I have also search everywhere and to no such luck.
Old 03-15-2005, 11:52 AM   #10
they used to be on 3.8 everywhere but i dont think they are anymore
Old 03-15-2005, 12:33 PM   #11
RGR
More proof that intake heat reduction is a geat idea:
They are making entire intake manifolds from the stuff,
also the Corvette LS1 is plastic, and so is the 4.6 Mustang
intakes... heat reduction WORKS and OEM's are doing it too!
Here's a link to some new neat stuff! New Stuff including the manifold above ^^^
Intake spacer sledgehammer Pre-2005 V6 Mustang 5 12-11-2009 07:46 PM
FS: 94-98 Intake Spacer drummerstang98 Mustang Parts for Sale and Wanted 1 03-24-2006 02:36 PM
99+ 3/8 intake spacer DarkStang Mustang Parts for Sale and Wanted 2 07-22-2004 10:59 PM
10:37 AM
