The roots is goin on finally!!!!! - Mustang Evolution
Old 06-21-2009, 10:04 PM   #1
RyansQuick6's Avatar
I was supposed to get it tuned tomorrow, but it looks like I'll have to push that back to tuesday unfortunately
And then....
RyansQuick6 is offline   Reply With Quote
Old 06-22-2009, 07:11 AM   #2
runvsofthisbull's Avatar
Re: The roots is goin on finally!!!!!
Nice brother. What kind of upper intake is that? Is it a kit? Also what supercharger did you choose to go with and would it clear a stock hood or no? Kenne Bell?
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 06-22-2009, 07:28 AM   #3
what cooling solution are you going with
Old 06-22-2009, 08:29 AM   #4
Hopefully a good one cause the KB's get pretty hot.
Old 06-22-2009, 10:29 AM   #5
The heat issues aren't what everybody assumes. There are now guys running around, even in this heat, with an eaton and only making 110* IAT's, with H20/meth. It seems people are starting to work the bugs out of this thing. It'll be at Stang-Hi tomorrow, so it can get tuned wednesday while I'm out of town.
I was gonna drop it off today, but I lost the idler bolt that I made and had to get a new one this morning.
Old 06-22-2009, 10:34 AM   #6
I wasn't referring to IAT's...I'm referring solely to the temps of the blower. As I have found out first hand, the KB's are a hot *** blower even without going into boost.
Old 06-22-2009, 11:37 AM   #7
Oh ok, my bad. One of these days it might get a whipple, but it'll most likely have twins on it long before that.
Don't you have a 2.8 on yours?
Old 06-22-2009, 11:55 AM   #8
No, I wanted the KB scream so I went with the 2.2...
Old 06-22-2009, 12:03 PM   #9
yea I like the KB's and whipples... but they HAVE to make noise....
Old 06-23-2009, 06:04 AM   #10
+1, gotta have the scream or nothing at all.
96 GT- Who knows what's in it.
Old 06-23-2009, 08:24 AM   #11
For me it absolutely has to be one way or the other, I either want it so loud that everyone in town can hear it, or absolutely silent so nobody has a clue until i pop the hood.
Old 06-23-2009, 08:39 AM   #12
Well, you should be spinning that 2.8 slow enough that no one should be able to hear it even with the hood popped.
Old 06-23-2009, 09:54 AM   #13
whats up with your seats, they seem like each is custom but each is different?
Old 06-23-2009, 10:12 AM   #14
jimmy_beaner's Avatar
Region: Iowa
THEY ARE! good catch
Old 06-23-2009, 08:05 PM   #15
One was leaned forward lol
Old 06-23-2009, 08:13 PM   #16
hottcobra's Avatar
you got it finished?
Old 06-24-2009, 05:47 PM   #17
nope, had to go to Houston for a project meeting. It's all the little things that I want to be done in a particular way that are taking me the most time, and most of that time is spent on the road hunting down connectors and adapters and stuff like that. I'm amazed at how difficult it is to find real vacuum hose in baton rouge.
Old 06-25-2009, 08:43 AM   #18
What exactly is a "real vacuum hose"? I found one that was a solid, 3d object in about 5 minutes including drive time. Unless something in a box that says vacuum hose isn't really vacuum hose.
Old 06-25-2009, 10:55 AM   #19
Due the obvious difference in fittings and connections, Advanced, PepBoys, and AutZone only have fuel line and stuff like that, the only "vacuum" hoses I can find are too small.
The issue is that the fuel line will collapse. It looks like I'm going to use it temporarily and then go back and make the system much cleaner and eliminate as many adapters jointed sections as I can.
Old 06-25-2009, 11:38 AM   #20
i hate messing with vacuum lines always a pita
Old 06-25-2009, 06:50 PM   #21
Now the issue is the belt, and me being a ****** with a part number generator
roots blower oaktonarcher Pre-2005 V6 Mustang 4 05-15-2007 09:18 AM
centrifical or roots o3mustangGTafs 1996-2004 Mustang GT 17 08-28-2006 07:07 AM
roots? oaktonarcher Pre-2005 V6 Mustang 7 04-03-2006 08:54 PM
roots blower charkelly9 Pre-2005 V6 Mustang 3 08-25-2004 09:36 PM
roots blower finally on tire The Bar 11 03-31-2004 11:19 AM
02:07 PM
