cutting stock springs - Mustang Evolution
Old 06-21-2009, 10:39 PM   #1
The stock 4x4 appearance of my car is driving me nuts. Unfortunately, I can't make eibach springs happen right now...so I was considering cutting the stock springs to lower the car. I'm looking for a 1.5-2inch drop
Is this possible, if so, at what point in the coil should I cut them?
Correct me if I'm wrong: Fronts- bottom of spring Rears - top of spring
This would be a temporary thing until I can get the eibach springs/cast and camber plates later on. I know people have done it, but if it'll harm the car in the long run, I'll wait.
Old 06-22-2009, 07:29 AM   #2
Re: cutting stock springs
you can cut the stock springs, but you will need caster/camber plates to align your car, if you cant do springs cc plates wont do either as they cost just as much just save up for a bit longer.
Old 06-22-2009, 08:29 AM   #3
DarkShadows's Avatar
should of bought the springs i was selling for half the price of new ones. would of worked great for ya.
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 06-22-2009, 01:18 PM   #4
Yah by the time I saw the listing they were sold
Old 06-22-2009, 01:20 PM   #5
I suppose running the car with cut springs w/o cc plates for 2 months would wear the tires unevenly...which would suck majorly
Old 06-22-2009, 01:48 PM   #6
yes it would.
Old 06-22-2009, 10:59 PM   #7
Originally Posted by DarkShadows View Post
yes it would.
Damn! Damn! Damn!
If only taking the iso's out lowered the car more than .25" I'd do that for now.
But it's really not worth taking everything apart just for that...oh well, guess I'll wait until I can get both the springs and cc plates.
Thanks guys
Old 06-23-2009, 07:21 AM   #8
honestly any less than 1.5 inches is a let down... 1 inch is barely noticeable.
Old 06-23-2009, 01:21 PM   #9
Herbstang's Avatar
Cutting your springs is one way of improving the looks of your Mustang
To get the proper height, start at 3/4 of a coil all the way around, and let it settle for a few weeks. It will most likely drop up to 1/4" during settling alone, aside from what you removed. DO NOT USE HEAT TO CUT THEM!!!!! use a cutoff wheel Don't let it get too hot. If you want to go lower, do it 1/4coil at a time, at the most, and let settle again for a few weeks again. It sucks to cut too much, because there's no way to put it back.
Old 06-23-2009, 01:28 PM   #10
Aren't the rear springs on GT's/V6's progressive rate springs? If so, they should not be cut...only linear rate springs can be cut.
Old 06-23-2009, 04:41 PM   #11
I thought the stock springs were linear...in that case it the spring rate wouldn't change if cut. I'm just not sure, I've heard so many mixed reviews about cutting the springs.
Old 06-24-2009, 07:21 AM   #12
the stock springs are linear
cutting springs? BlackSix Pre-2005 V6 Mustang 17 11-24-2008 09:50 PM
cutting springs.. x99xstangxx Pre-2005 V6 Mustang 11 11-07-2007 07:03 AM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 12:13 AM
Cutting Your Springs megax29 Pre-2005 V6 Mustang 45 10-13-2004 04:36 PM
cutting C springs ???? Zim Pre-2005 V6 Mustang 8 06-24-2004 12:59 PM
12:12 AM
