4.0 V-6 mods, whats out there - Mustang Evolution
Old 03-17-2005, 01:07 AM   #1
Send a message via AIM to JHL981
Im new to the whole mustang scene, but what kind of mods can i do to a 4.0 V-6 in my 05?
JHL981 is offline   Reply With Quote
Old 03-17-2005, 10:09 AM   #2
RGR
Send a message via AIM to RGR
Basically anything to the engine that you can do to the older V6,
there are no stroker kits yet and I am working on cam regrinds
and something else but you can get porting and maybe TB's...
I believe there may be UDP's available and certainly an exhaust
could be made to work... What did you have in mind? I can be more
specific if you tell me what you want to do.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-17-2005, 11:33 AM   #3
i would wait a bit on the more extreme mods, let the aftermarket catch up. perhaps exhaust and a shifter (unless you got an auto.....) stuff like that.
Old 03-18-2005, 01:51 AM   #4
Like some mods under say $300. SOmething to give the engine some pep. Like on my old ranger, there was an airbox mod, a MAF mod, TB mod, stuff like that
Old 03-18-2005, 08:06 AM   #5
RGR
Leave the MAF alone, unless you just want to smooth it out,
but leave the post in there. I have a 1/2 shafting how-to
somewhere that I did a long time ago, it is easy, adds
maybe 15% more flow and adding a CAI will be great too.
That gives you a good filter and no airbox to impede flow.
Here's a link to a site that shows 1/2 shafting and it has some pix
for doing a 94-98 3.8 TB. I noticed this guy used info for intakes off of
GrapeApe racing and did not note that it was from there, and used the
1/2 shaft thing and did not note that... but at the bottom of his site
he has a copyright warning,
http://rogueperformance.com/UpperIntakeManifold.html
This is a ranger mod page, TB 1/2 shafting is quite similar
despite TB size or design. It's not a bad guide but the guy
lets on like he invented the concept. We know better
Old 03-18-2005, 03:20 PM   #6
Send a message via AIM to NJStang86
Your car is pretty new, and so is the aftermarket for it...
I'd wait awhile and let the companies test their products. Prices for the products now are pretty expensive for the 05 because there aren't as many competitor products.
If I were you, I'd definately wait until more people get their hands on the 05.
-Frank-
http://home.earthlink.net/~riz3742/sig2.jpg
2003 Ford Mustang Dark Shadow Gray Coupe - 15.616 @ 87.24 (work in progress)
NJStang86 is offline   Reply With Quote
Old 03-18-2005, 04:29 PM   #7
RGR
When you want porting I'd do an R&D discount later, after I get everything else in order.
I love new projects! I generally do them cheap, if you get cores for me. There should
be lots of cores available, 4.0 Explorer engines have been around for years now.
Old 03-18-2005, 04:46 PM   #8
i was reading about someone making 24 valve heads for it.
Old 03-18-2005, 05:38 PM   #9
wiarumas's Avatar
i personally would get dual exhaust. a lot of people get flowmasters, spintechs, etc. that should be around the 300 mark. call around and ask for prices for a custom job. don't go more than 2.25" piping though unless you are for a fact supercharging later. im not sure though.. any comments anyone on my suggestion?
Old 03-18-2005, 11:15 PM   #10
Kiljosh's Avatar
2.25 to 2.5 is ok I think. The 2.25 is great for stock engines but 2.5 won't hurt. PLus you'll be ready for anything you might want to do in the future.
Check around online and see if anyone sells UD Pulleys for 4.0 Explorers and compare the price to anyone happen to be selling pulleys for the 05. I'm not sure but I would bet the pullies would fit fine and give a good pep, better mileage, and throttle response for only like 80-120 bucks.
Then get yourself a CAI, and some mufflers. Save up and have a shop make you an exhaust. If you goto a locally owned shop and the guys a mustang nut he may give you a deal since you'll be prob the first 05 he had the privelege of working on.
Old 03-18-2005, 11:19 PM   #11
01mineralgrey6's Avatar
good point:yup:
-Tony
'99 cobra 'vert
Old 03-19-2005, 05:25 AM   #12
Thanks for all the great advice. The last flowmaster that I had on my truck, didnt give it any power, just sound, is it because i chose the wrong one or something? I dont want to get an exhaust and not have some gain
Old 03-19-2005, 11:15 AM   #13
wiarumas's Avatar
i dont think the mufflers will give you any gains.. they might.. but its probably so small lets not even count it.
its the dual exhaust that will help you. on stock mustangs the single small exhaust is a bottleneck for airflow. if you get duals you will gain horsepowers... and the mufflers are for sound. you'll probably notice alittle loss in torque but you'll feel the difference in horsepower. id say probably around 2-10. dont expect large results though.. every little bit helps. get a CAI to help more air get into the engine so more can get out. with those 2 installs you can definitely feel a nice improvement over stock. once again, its not a supercharger or anything haha but you will notice it.
the reason why i suggest getting the duals is that it is probably the first mod you do to your car that LOOKS different from stock. both you'll notice it and others will notice it because the way it looks and sounds.
Old 03-19-2005, 12:54 PM   #14
Can I even have dual exhaust considering there is a cutout for only one pipe?
Old 03-19-2005, 01:00 PM   #15
RGR
You would need a conversion, the fake duals can bolt on
buit they retain the stock "Y" pipe and that is the most
restrictive part of the system IMO. That and the single
stock muffler.
Old 03-19-2005, 01:14 PM   #16
RGR
Get True Duals...
True Duals Rule!
Old 03-22-2005, 05:26 PM   #17
silverstangboy's Avatar
they're is a cutout in the rear bumper correct?
93 mustang notch
~450hp 331 stroker - Sold
Old 03-22-2005, 06:22 PM   #18
The 05 6ers have a single cut out for exhaust...that's what he's talking about.
Old 03-22-2005, 08:07 PM   #19
yeah, having to swap rear pieces... well that sucks
93 mustang notch
Old 03-23-2005, 09:43 AM   #20
give the aftermarket a little bit to catch up
Old 03-23-2005, 12:16 PM   #21
RGR
Being the first to do something is nice though!
Old 03-30-2005, 04:17 AM   #22
I think I want to put headers on, will those make a difference? and what kind?
Old 03-30-2005, 06:57 AM   #23
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
they'll make a difference. but headers + h pipe + dual exhaust = EXPENSIVE!
check this out, these are some of the things you can already get...
http://shops.wholesale411.com/mattie...p?cPath=18056&
most of it is GT stuff, but there are a few v6 items
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 03-30-2005, 07:28 AM   #24
We have heads, cams TBs etc. etc. Still getting a power pack together for it.
AlmostN8 is offline   Reply With Quote
Old 03-30-2005, 08:58 AM   #25
Could always run dumps till new bumpers start coming out...
Old 03-30-2005, 10:25 AM   #26
wiarumas's Avatar
depends on how far you want to mod your car. are you planning on modding a lot and pumping out big numbers or are you going to put on something like.. an intake, exhaust and maybe a pulley. if you plan on modding a lot in the future then id say headers but its not really necessary if you dont plan on modding passed the first stage. just my opinion though.
Old 03-30-2005, 01:11 PM   #27
RGR
I'd hold off on headers too, unless big future mods are planned.
I can get you a cam and P&P too, anything you'd need... plus
it is nice to stay with a Mustang Evolution sponsor like RDMotorsport
Something like that level could likely use the headers. The 4.0 is an RPM
motor even more so than a 3.8, it has a bigger bore and OHC so I'd suggest
an RPM-oriented combo. But building for torque is a never-miss way to go too!
Whats Up Whats Up From Georgia ShesmuRa New Member Introductions & Greetings 6 11-02-2009 02:23 PM
Whats this? D-Nice 2005-2010 Mustang GT 19 07-20-2009 11:44 PM
whats up mustanglvr New Member Introductions & Greetings 11 04-16-2009 07:18 AM
Whats the most... damustangfan14 The Bar 13 09-28-2004 05:19 PM
whats the better rpm curve?/whats a good car choice? Thomas91169 The Bar 7 12-05-2003 10:24 PM
01:26 PM
