MAF Po102 - Mustang Evolution
Old 06-23-2009, 06:44 AM   #1
McGrail482's Avatar
Region: West Virgina
Send a message via AIM to McGrail482
MAF Po102
Last week i got low on gas and the car wouldnt move when i hammered down on the accelerator. I filled it up and let it run for 20 minutes and i was able to drive it but now the engine light is on with a Po102 code. I have a bbk cai, so yesterday i cleaned the filter and the maf (very dirty) and reset the computer but the light came back on. Could the maf sensor be bad and are there any ways you can tell? Also where is a good site to find one, ive been looking on ebay but thats about the only place i can find one.
-Jason
2015 5.0 Mustang
Previously Owned:
1995 3.8 V6 Mustang-True Duals w/Mac Flowpaths, BBK CAI
2012 Ford F150 FX4
McGrail482 is offline   Reply With Quote
Old 06-23-2009, 07:18 AM   #2
Re: MAF Po102
right after you clean your air filter (re oil it) the oil will be generally to much (its hard to get the exact amount everywhere... just the way it is) so the extra oil gets sucked into the intake and gunks up the maf and such.
Get some on contact no residue electronic cleaner and clean the maf really good, also if you wish (if idle is off or bad) clean the IAC, its the little cylinder round thing by the throttle body~ it controls idle~ and may be gunked up a little as well, you can try the maf first if you wish.
Also make sure the air filter is tight and no air is escaping or getting in thats not trough the air filter.
Old 06-23-2009, 07:24 AM   #3
McGrail482's Avatar
Re: MAF Po102
yeah i cleaned the maf yesterday with electrical cleaner but ill try cleaning the iac. thanks
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-23-2009, 10:11 AM   #4
McGrail482's Avatar
Re: MAF Po102
At what rpm's should it be idling.
1995 3.8 V6
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-23-2009, 01:51 PM   #5
Herbstang's Avatar
Re: MAF Po102
P0102 is the Mass Air detecting low input like Brandon said clean the MAF and IAC Check for vacuum leaks
Old 06-23-2009, 07:28 PM   #6
McGrail482's Avatar
Re: MAF Po102
cleaned the IAC and so far so good, engine light is off
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-24-2009, 06:12 AM   #7
McGrail482's Avatar
Re: MAF Po102
Light came back on the way to work today, after cleaning the maf, iac, and the throttle seems to be running alot better than it was. It doesnt seem to respond well when i accelerate from a stop. Anything else i can try or should i start with replacing the maf and iac?
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-24-2009, 07:08 AM   #8
Re: MAF Po102
those iac's can be pesky, just keep an eye and if idle issues come back replace it. You can make double sure the maf is good and clean else you can try a replacement then.
Old 06-24-2009, 09:52 AM   #9
Herbstang's Avatar
Re: MAF Po102
here's a good article about cleaning the MAF,TPS,IAC TB and how to reset base lines Ford Mustang IAC IAB - Solving your idle problems
Old 06-24-2009, 09:53 AM   #10
McGrail482's Avatar
Re: MAF Po102
Is there a way to tell if the maf or iac is malfunctioning when they are unplugged? If they are unplugged is it going to increase or decrease my performance?
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-24-2009, 09:59 AM   #11
Re: MAF Po102
hmm the IAC im not sure about, sometimes they just mess up. I am betting they are kinda working and unplugging them will just make it worse.
Old 06-24-2009, 10:09 AM   #12
Herbstang's Avatar
Re: MAF Po102
you'll get surging or variance in idle speed when the IAC is unplugged it should die or almost stall out with the IAC with the IAC plugged back in the idle surges high, then immediately settles back to normal
Old 06-24-2009, 11:09 AM   #13
McGrail482's Avatar
Re: MAF Po102
yeah i unplugged my iac on my lunch break and tried to start it back up and it just died...I never got an answer earlier but at what rpm should it idle at when its sitting in park?
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-24-2009, 12:21 PM   #14
Herbstang's Avatar
Re: MAF Po102
automatic transmission it should idle at something in the 600 to 650 rpm range in drive. That would have the idle in park around 800 with no A/C and around 900 with A/C.
Old 06-24-2009, 12:55 PM   #15
Herbstang's Avatar
Re: MAF Po102
Here's a little something I found on the TPS
Hope this helps explaining more about it The TPS is reset at startup AND while the car is running Forget the year that the ford TPS were no longer adjustable
Mustang TPS FAQ
Old 06-24-2009, 01:11 PM   #16
Re: MAF Po102
my 01 v6 would idle rough below 600 rpms~
Old 06-24-2009, 05:33 PM   #17
McGrail482's Avatar
Re: MAF Po102
alright so my car idles to 750rpm when it starts up and falls down to 500rpm in park. In drive it jumps up to 650rpm and abot 750 with the ac on. When i unplug the maf it doesnt change at all. Shouldnt unplugging the maf cause a decrease in performance? Can't hear any leaks. I feel like its the maf.
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-25-2009, 11:47 AM   #18
Re: MAF Po102
unplugging the maf should make it run horrible and die~ I forgot to plug mine in one time and I had black smoke out the back of my car from running very rich lol.
you can probably grab a sensor at a junk yard cheap~ you can check the voltage of it if you want to see if its in spec (not sure what spec is(
Old 06-25-2009, 11:58 AM   #19
McGrail482's Avatar
Re: MAF Po102
when its plugged in it runs the same as unplugged (very sluggish), so that makes me think it is for sure the maf. is there anywhere i can get just the sensor or does it always come with the housing or spector is that what you ment when you said to go to a junkyard.
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-29-2009, 06:32 AM   #20
McGrail482's Avatar
Re: MAF Po102
Replaced maf, light off. Thanks spector and herb
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-29-2009, 07:01 AM   #21
Re: MAF Po102
good to know, does it run/idle better?
Old 06-29-2009, 09:43 AM   #22
McGrail482's Avatar
Re: MAF Po102
it runs 10x better but i can't remember at what rpm it idled before cause its been sitting in the garage for a few years while ive been in school. it sits at 500-600 rpm in park and drive.
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
MAF bsmith782 1996-2004 Mustang GT 12 01-30-2007 04:07 PM
90MM MAF DarkShadow Mustang Parts for Sale and Wanted 9 11-29-2006 10:11 PM
MAF gone bad powerhungry966 Pre-2005 V6 Mustang 5 01-24-2006 12:07 PM
Maf ? FloMasta24 Pre-2005 V6 Mustang 8 02-24-2005 06:07 PM
is this what your MAF looks like.... project232 Pre-2005 V6 Mustang 13 02-23-2005 03:47 PM
06:16 AM
