largest engine? - Mustang Evolution
Old 03-18-2005, 11:35 AM   #1
02BLUE_STANG's Avatar
Send a message via AIM to 02BLUE_STANG
Lightbulb largest engine?
anyone know what is the largest engine possible that would fit in an 02 mustang.. im just cerious beacause i decied to just put a the biggest engine that would fit into my car rather then buying a new one.. wasent planning on doing it soon maybe in a few years lol
02BLUE_STANG is offline   Reply With Quote
Old 03-18-2005, 12:16 PM   #2
wiarumas's Avatar
depends on how much money you want to spend. you can pretty much drop anything into it with the right amount of money. however, if your pockets arent that deep i suggest going with the 4.2...
however, if you do have a big of money to throw around... 5.0
Old 03-18-2005, 12:21 PM   #3
3.8, 4.2, 4.6, 5.0, 5.4 SOHC or DOHC, 6.8. That's about the choices available today that will fit in your engine bay.
Old 03-18-2005, 01:26 PM   #4
RGR
Send a message via AIM to RGR
672 CI, stroker big block
Biggest V6 would be around a 4.7 possibly...
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-18-2005, 01:26 PM   #5
I don't believe a 672 will fit in the engine bay.
Old 03-18-2005, 01:30 PM   #6
RGR
It would just be a little more work than anything else would.
Gas Axe time possibly... easier than adapting wiring harnesses
and stuff like that. But then again I have made my own motor
mounts and done extensive fabrication work too, that does not
scare me. Most people want a drop-in install.
Old 03-18-2005, 01:31 PM   #7
Hm..I might look into those. I don't mind fabbing stuff up, actually love doing it.
Old 03-18-2005, 01:35 PM   #8
RGR
It is a 5" stroke, 4.625" bore on a Motorsport Block...
a 557 would be cheaper by far, you could actually
afford to put heads on a 557 but the 672 heads might
cost as much as the whole 557 long block!
Old 03-18-2005, 01:36 PM   #9
Bane-'s Avatar
i wouldnt consider a 5.0 swap big money...for the price of the stroked 4.2 you can prally throw in a 5.0...but both will be putting down similar numbers or the 4.2 might even be a little higher..(a stock 5.0 atleast...but who likes stock?)
Old 03-18-2005, 02:24 PM   #10
Danger Dude's Avatar
3.8, 4.2, 4.6, 5.0, 5.4 SOHC or DOHC and the 5.8 found in the 95 Cobra R
Old 03-18-2005, 03:25 PM   #11
Zim
You want to **** me?
Zim's Avatar
95 cobra R's are sweet... my old neighbor back home has one that he dumped 14 grand under the hood into. That thing was so badass... it was white with 2 10" blue racing stripes all the way along the body. Id get a boner everytime i saw that car....
I like toys
Old 03-18-2005, 08:12 PM   #12
Send a message via AIM to mustangmike524
thats something you keep to yourself from now on.
Mike aKa The ORIGinal STANGsta
http://www.mustangevolution.com/foru...ine=1102790426
mustangmike524 is offline   Reply With Quote
Old 03-18-2005, 10:43 PM   #13
Ponycarman's Avatar
Stuck on Ford power?
If not an Allison V12 will fit, 1710 cid, 1600 hp stock. Of course a bit of fabbing will be required, lol.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 03-19-2005, 12:08 AM   #14
Kiljosh's Avatar
V12 mustang...that'd be disgusting.
Can anyone say viper-eater?
Old 03-19-2005, 01:43 AM   #15
Ponycarman's Avatar
Viper nothing, you name it eater. F1 here I come! lol
Steve
1996 Mustang
1965 Barracuda
Old 03-19-2005, 09:23 AM   #16
RGR
Cheapest and easiest is going to be the V6 stroker.
A 300 RWHP street 4.2 will happen this year probably,
I have some people for new cams that could do it.
The longblock is not a huge obstacle, just the cam design.
I have 2-3 cams on my list that can make it! Totally streetable too!
Mild heads, good intake porting and great cam will get a 4.2
stroker into the 300 RWHP range. That would make it a really
cheap and easy option for your needs, also looking at a 6500 RPM
limit on it so high RPM is not needed. It'll probably hit it at 6K actually.
Old 03-19-2005, 09:37 AM   #17
Steve
i got one of those sitting in my garage.
Old 03-19-2005, 05:51 PM   #18
Ponycarman's Avatar
I got a sawzall, a torch and a welder. Let's rock!
I'll buy the beer, you buy everything else and your Stang will rule the world!
Steve
1996 Mustang
1965 Barracuda
Old 03-20-2005, 01:33 AM   #19
Steve
lol, come to LA i got access to all the tools we need and a lift.
but i may have lied about having the engine
Old 03-20-2005, 05:09 AM   #20
Ponycarman's Avatar
LA?
No thanks, too crowded, too crazy. I lived in San Diego for 10 years and hated it each time I went to LA, which was about once a year. I miss San Diego sometimes though.
Steve
1996 Mustang
1965 Barracuda
Old 03-20-2005, 11:49 AM   #21
the largest engine and most power are two different things. I would just set a goal of what I wanted the car to perform like and then work for that however you best see fit, but dont just stick a huge motor in it and expect her to be the badness.
Old 03-20-2005, 04:17 PM   #22
Ponycarman's Avatar
No replacement for displacement
Steve
1996 Mustang
1965 Barracuda
Engine noise from COLD engine 03GreyMach1 1996-2004 Mustang GT 10 03-14-2008 08:40 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 02:59 PM
Dems Want Largest Tax Hike In History. Rollinthundr The Bar 62 03-29-2007 11:03 PM
Do you need a 5.0 engine 89forparts Mustang Parts for Sale and Wanted 8 10-18-2006 07:21 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 03:01 PM
03:59 PM
