2000 v6 shakes when i fully stop - help! - Mustang Evolution
Old 06-23-2009, 04:39 PM   #1
CHILE10_STANG's Avatar
Unhappy 2000 v6 shakes when i fully stop - help!
WHENEVER I COME TO A FULL STOP MY CAR SHAKES AND THE RPM DROPS TO ABOUT 600/700.
I DID A TUNE UP TWO DAYS AGO - AFTER I CHANGED THE SPARK PLUGS AND THE WIRES IT WAS FINE FOR THAT WHOLE DAY NO SHAKING. TODAY IT STARTED SHAKING AGAIN AND I DONT KNOW WHAT IT COULD BE. IT ONLY DOES IT WHEN I COME TO A STOP.
CAN ANYONE GIVE ME ANY IDEAS ON WHAT IT COULD BE?
CHILE10_STANG is offline   Reply With Quote
Old 06-23-2009, 05:08 PM   #2
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: 2000 v6 shakes when i fully stop - help!
did you unplug or bump any ABS sensors/wiring?
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 06-23-2009, 05:23 PM   #3
Otlaw80's Avatar
Is it while your are stoping? or after you stop? If its after u stop, it could be a vacuum leak. Check all your lines. If it's while you are stopping its most likely warped rotors or an abs prob.
Old 06-24-2009, 07:19 AM   #4
clean your MAF air sensor really good (especially if you have a K&N or other oiled air filter element) and clean/replace your IAC (round cylinder thing near the throttle body on the upper intake) if the car wont idle very good, it should idle around 650-700 rpms, if the AC is on it might dip down now and again when sitting still.
Double check the spark plug wires, it may be a coil pack messed up and a couple cylinders are not firing
Old 06-24-2009, 09:36 AM   #5
IT HAPPENS WHEN I FULLY STOP... ITS NOT A HUGE SHAKE, BUT IT DOES SHAKE AND I DONT LIKE IT...
Old 06-24-2009, 10:06 AM   #6
see if the rpms drop right as it shakes~ I am willing to bet they do (seems if they go unver 600-550 my old 01 v6 car would shake)
let me know
Old 06-24-2009, 05:06 PM   #7
Yea bro... The car shakes as the rpm drops...
Were you able to fix yours?
Old 06-25-2009, 11:49 AM   #8
you can alter the idle of the car if that turns out to be the problem (as a temp fix I think your car has an idle screw that you can turn to make the car take a bit more gas, its near the throttle body) but it all points to the maf/iac~ sensors that control the idle~
68 302 shakes badly at idle after T5 swap TEvans720 1979-1995 Mustang GT 6 05-14-2010 06:33 PM
F/S Fully Built 2001 Mustang GT...LOOK code3GT Mustangs for Sale and Wanted 0 10-18-2005 03:00 PM
mustang engine kinda shakes?! mexor The Bar 29 09-17-2003 09:01 PM
02:45 AM
