fuel octane - Mustang Evolution
Old 03-21-2005, 12:22 AM   #1
Send a message via AIM to charkelly9
fuel octane
instead of putting the lowest octane fuel in your v6.. would it hurt the engine, help the engine or do nothing to put the middle octane between premium and regular in your car when you gas up?
charkelly9 is offline   Reply With Quote
Old 03-21-2005, 12:30 AM   #2
Makes no difference on a stock engine if you use mid or premium. Your engine is tuned for regular.
Old 03-21-2005, 05:48 AM   #3
Danger Dude's Avatar
There is a myth that higher octane hurts cars AND THAT IS A LOAD OF CRAP!!! The fact is if it was harmful they would post it on the car as a warning or they would post it at the pump. The only reason not to run higher octane is that it is a waste of money PLAIN AND SIMPLE!!!
Now saying that if you live in a state like California with crappy gas you might have to go to mid grade so the octane is at the required level. There are many people on the forums that have said they have had to use higher octane to prevent their car from knocking or pinging.
Old 03-21-2005, 10:37 AM   #4
here in LA regular works great for the stang no pinging no knocking. the reason that our stangs dont have to use higher octane fuel is because we dont have the compresion to make good use of it.
Old 03-21-2005, 10:39 AM   #5
I run 87 in my car...I've ran 93 before, and couldn't tell a single difference, so I just stick with the cheaper stuff, esp with gas prices how they are now.
Old 03-21-2005, 01:22 PM   #6
Send a message via AIM to NJStang86
I've run 87 since I've gotten the car...
No need to be spending 10-15 cents more per gallon on a pretty much stock car. I'll do the change once I get tuned and have my gears installed.
-Frank-
http://home.earthlink.net/~riz3742/sig2.jpg
2003 Ford Mustang Dark Shadow Gray Coupe - 15.616 @ 87.24 (work in progress)
NJStang86 is offline   Reply With Quote
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 03:32 PM
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 03:22 PM
92 Octane for Nitrous? v0nz Pre-2005 V6 Mustang 5 12-03-2009 12:10 PM
What octane to use chamillionaire Pre-2005 V6 Mustang 8 03-27-2006 09:34 AM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
05:38 AM
