faq - Mustang Evolution
Old 08-04-2003, 11:55 AM   #1
Send a message via AIM to el cheapo
faq
thought this should be added to the sticky, but i didnt want to mess it up, it looks so good. Heres my question:
What is the diffrence in a strut tower brace and a anti-sway bar?
They do the same thing, right?
But they are two diffrent things?
thanks
damn it school, why do you suck so bad??
el cheapo is offline   Reply With Quote
Old 08-04-2003, 12:34 PM   #2
tire's Avatar
Send a message via AIM to tire
hahaha no, 'anti-sway bar' = 'sway bar', shortened.
strut tower braces go above the engine bay keeping the strut towers from flexing inwards while cornering.
tire is offline   Reply With Quote
Old 08-04-2003, 02:30 PM   #3
right.
I got that much.
So a sway bar mounts to the chassis, And its job is to prevent body roll.
Right?
Old 08-04-2003, 02:43 PM   #4
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
No, a sway bar connects the lower control arms in the rear of the car and helps hold both tires to the road.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 08-04-2003, 02:47 PM   #5
ahh. Ok. thanks guys. Love the info
Old 08-05-2003, 07:06 PM   #6
tire's Avatar
Right?
sorry for laughing at you.
body roll is affected by the suspension that is under it, not by bolting things to the chassis itself to keep it from flexing. a STB maintains the integrity of the chassis and the front sway bar reduces understeer/increases oversteer and does lessen body roll, but they are so neccessary, people don't usually refer to them as 'lessening body roll' as 'if you turned going more then 15mph you'd lose control and die'. for almost all street apps your rear sway needs to be thicker than the front. otherwise you get mad oversteer and that's almost as bad as not being able to turn as you'd like (understeer). subframe connectors maintain integrity of the chassis by, well, what the name says.
Old 08-05-2003, 08:17 PM   #7
Right?
its all good. I didnt take it badly.
Im thinking about just hooking up with a stb and some subframes. hows that sound?
Old 08-05-2003, 08:22 PM   #8
tire's Avatar
the 99+ are stronger up top. STB's aren't needed much, but supposedly make a bigger difference on 94-98's.
i'd invest in subframes with or without cross braces welded on and a rear sway bar if you don't already have it.
what exactly are you going for, chassis stiffness, handling, launching, what?
Old 08-05-2003, 08:29 PM   #9
Well, cornering and launching mainly. Id like to be able to go through corners without feeling like the body of the car is going to fly off the wheels. I guess lowering springs should be the first thing, huh? and shocks/struts.
Old 08-05-2003, 08:54 PM   #10
shocks struts springs and subframes with seat tracks.
Youll feel pretty solid with just that.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 08-05-2003, 08:58 PM   #11
tire's Avatar
what he said.
the shocks and struts just bolt on.
the springs will need spring isolators and shorter endlinks which will cost you the spings plus about 75$.
Old 08-05-2003, 09:47 PM   #12
so much money. . . i am too cheap for this car stuff hahah
Old 08-06-2003, 04:00 AM   #13
tire's Avatar
doing it right the first time is essential though.
in fact, coil overs out perform regular springs if you really want the best.
want to hear about them?
Old 08-06-2003, 06:40 AM   #14
haha, sure. If you wanna tell me about something im always willing to listen. I was actually wondering what coil overs were all about.
Read a little about them i think they replace the regular springs somehow, and lower the ride, and make suspension stiffer. and empty your wallet
Old 08-06-2003, 10:45 AM   #15
tire's Avatar
they aren't horribly expensive, but they are more than lowering springs. they are lighter than a car with springs and have an adjustable height. you can lower it down for autox and raise them for highway driving. i'm not really in the mood to continue, i'll post later about it.
go to www.howstuffworks.com and you can find out better info than anyone here will tell you.
Old 08-06-2003, 12:27 PM   #16
Rick0636's Avatar
Customizing/modifing cars is expensive, whether you do it yourself or pay someone to do the work for you. I am a disabled veteran on fixed income so I have to be extra careful of what I spend, its really a tough hobby for me, but I do manage to do most of my own work, I don't do transmission work or ring and pinion swaps and a few other things, but most I can do right out in the back yard under my carport, lol.
Old 08-07-2003, 05:50 PM   #17
Send a message via AIM to 94GTStang
You can reuse your spring insulators since your car is still new. They don't wear out that fast. Plus they run about $20 each at the Ford parts counter.
Check out my website to see my rides!
www.geocities.com/GTStanger94
94GTStang is offline   Reply With Quote
Wheels and Tires FAQ SpectorV Mustang Wheels & Tires 11 04-12-2015 01:54 PM
The Ultimate General Information FAQ FAQ Brent ME Site Help & Announcements 1 03-24-2011 04:41 PM
Rear End Gear FAQ OsirisGuy General Mustang Discussion 18 11-10-2009 12:22 AM
Torque Converter FAQ STEVE Pre-2005 V6 Mustang 12 05-30-2005 09:55 AM
12:09 PM
