Dipstick fell off: - Mustang Evolution
Old 08-04-2003, 12:10 PM   #1
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Dipstick fell off:
Does this get welded on to the block?
Rellik is offline   Reply With Quote
Old 08-04-2003, 12:20 PM   #2
Danger Dude's Avatar
No the dipstick tube just pushes in and is held in place by a Header stud that the tube bracket slides onto and a nut holds in place
Old 08-04-2003, 01:03 PM   #3
damn, then how the hell did myn fall off.
Old 08-04-2003, 01:09 PM   #4
Did the attach point break off and is still attached to the motor or was it not attached. Is the flange still on the dipstick to install it to a header stud????
Old 08-04-2003, 01:17 PM   #5
Here are pics of it i had just taken, Is it broken? I have a spare block in my garage and it doesnt fit. The flange at the end of the dipstick tube is too large to fit the opening that i believe the dipstick goes into. Thinking maybe it snapped and left part of that tube in the block.
Old 08-04-2003, 01:32 PM   #6
Damn dude I not sure that your tube had the bracket welded to it like mine. I am not sure what type of tube is on a 95. The tube itself looks fine the necked down portion is there so I dont think any of the tube is broke off in the block. You should be able to by slowly twisting the tube with downward force get the tube back in there
Old 08-04-2003, 02:21 PM   #7
2 guys over at v6p told me its broken. Damn.
Old 08-04-2003, 02:35 PM   #8
So you go over to V6 power HUMMM!!!!!!!!!!! : : : Well it might be but there is a long portion neck down tube that is on the tube and not broke. all of the neck down should go into the block. thing is i can believe the tube does not have a bracket attached to it to hold it in place
Old 08-06-2003, 09:48 AM   #9
corey how do you get in there. I tried cant see ####.
Old 08-06-2003, 09:48 AM   #10
ps. i dont feel like taking my headers off either.
Old 08-06-2003, 10:30 AM   #11
Look at the header bolts the center 2 header pipes do either one have a stud instead of a bolt down there. The stud is where the bracket would attach. If not can you stick the tube back in the block and make it stay there and not wiggle around. Personally If it is broke off in the hole I would not try and fish it out now. Are you not going to be modding another engine. I would get some JB weld and make a batch up and apply it on the tubes out diameter 1 in above the end so as to not get any in the oil and shove it back in the hole and let it dry
Old 08-09-2003, 10:03 PM   #12
Old 08-09-2003, 10:40 PM   #13
Old 08-10-2003, 12:32 PM   #14
Rick0636's Avatar
Old 08-10-2003, 02:39 PM   #15
Help with tranny dipstick istrober 1996-2004 Mustang GT 0 04-13-2010 02:42 PM
The Front Fell Off! Brent Pictures and Videos 4 07-18-2008 03:25 PM
So I fell through the ceiling today... PureVenom The Bar 14 12-04-2007 06:51 PM
Oil Dipstick-94 GT Conversion to 69 FB emarsagl 1979-1995 Mustang GT 1 08-09-2006 08:35 AM
Oil Dipstick Question Kiljosh Pre-2005 V6 Mustang 9 03-16-2006 03:55 PM
06:24 AM
