vertical doors and final gears - Mustang Evolution
Old 03-22-2005, 07:04 AM   #1
Send a message via Yahoo to a1999ponyboy
i am also looking at a vertical door kit, is it worth it or not. also i have a set of 3.73 gears does any one have a web site that shows how to do it and all the specs
a1999ponyboy is offline   Reply With Quote
Old 03-22-2005, 07:10 AM   #2
wiarumas's Avatar
gears might/should be done professionally.
Old 03-22-2005, 07:14 AM   #3
is a 70 mm t-body to much for a n/a motor with a cam?
Old 03-22-2005, 08:41 AM   #4
I wouldn't do the vertical doors, there's so much more involved there than you think. You have to worry about the doors coming out from the side so they will clear the front fenders, the doors being able to seal, etc etc, I'd put that money towards something that would be worthwhile for the car and not lead to you getting pissed at it either.
Old 03-22-2005, 11:02 AM   #5
wiarumas's Avatar
for the price of the vertical doors you could easily gain a lot of horses. plus i dont know how credible most vertical door kits are out there..
Old 03-22-2005, 11:48 AM   #6
vertical doors are cool but they are just begging for issues... i wouldnt mess with em, to much money... but thats a personal desicion for what you consider taste in modifying a car.
Old 03-22-2005, 03:38 PM   #7
RGR
Send a message via AIM to RGR
Just putting it on is not as easy as it sounds. The IAC passages do not
line up properly and it needs modified. The TB is too big for the crossover tube
anyway, you need posts removed to use a 70mm TB effectively. I've done it
it fits great if you know what you are doing. In your case (NA 3.8 w/cam)
I'd just 1/2 shaft the TB and cal lit good. I have a how-to listed here:
1/2 shaft how-to (2nd post in thread)
Try that and it will be a great match for the NA 3.8 and a cam, even with porting.
See the other stickys for great V6 modding info!
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-22-2005, 05:08 PM   #8
Monkey's Avatar
^^ exactly. 70mm is too big for an N/A 3.8 motor unless you have a sheetmetal intake, fully stage 3 ported heads, wild cam, etc.
Old 03-22-2005, 10:29 PM   #9
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
When you remove those two bolts that run down through the TB crossover tube in the upper intake, does that have the possiblity of making the intake not seal right anymore? I mean, aren't those bolts there for a reason? Or are they relocated somehow?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 03-23-2005, 05:30 AM   #10
RGR
I use shorter bolts that are flush to the crossover tube floor.
Guess you could call it relocated... making them lower.
Old 04-03-2005, 06:59 PM   #11
can i do a half shaft on a 99 t body. how indepth is this ind do you have any pics
Old 04-03-2005, 09:15 PM   #12
RGR
Look here, Post #2 but no pix...
!/2 shaft text
03:22 AM
