Chip question - Mustang Evolution
Old 03-22-2005, 11:36 AM   #1
Chip question
Aight, I have a guy selling me a SCT tuned chip for my car tomorrow. I have a 2002 Automatic V6 with the PMP1 code. The chip is out of a 2002 Automatic V6 with the PMP1 code. This should be a dead swap right? No need to have the chip reflashed or anything. He's giving me a deal I can't refuse on it so if nothing else I'll install it for a little bit, get sick of using premium fuel, and keep the chip for when I want a little extra boost.
Old 03-22-2005, 11:39 AM   #2
Depending on what all it was burned for for his car
Old 03-22-2005, 11:40 AM   #3
Raise rev limiter, speed limiter, shift points. That's about it I believe. He had no mods on his car besides a K&N...so I figure my car having just a K&N and exhaust it should be a dead swap.
Old 03-22-2005, 11:41 AM   #4
why on earth would you RAISE the rev limiter for any where near a stock car... thats just ignorent....
Old 03-22-2005, 11:43 AM   #5
It's just like 300 or something like that, nothing major. His car would break loose between 1st and 2nd with this chip in on WOT. But normal driving it drove perfect, got 2-3 mpg more with it in.
Old 03-22-2005, 11:55 AM   #6
It will work...
Old 03-22-2005, 12:00 PM   #7
It will work...
Ha aight, that's all I was really wondering. Just don't wanna buy this, put it in and it screw over my computer. If nothing else, I could sell it and make money off of it.
Old 03-22-2005, 12:03 PM   #8
you need to get install instructions to make sure you do each step right, its not hard though.
Old 03-22-2005, 12:05 PM   #9
Yeh, he walked me through the install and said he'll help me with it saturday to make sure I do it right. He got it down to a 5 minute or so install, said the longest part was making sure the battery was completely drained before removing the computer.
Old 03-22-2005, 12:41 PM   #10
slvr2000stang's Avatar
Not really.
You can safely raise it some on a stock car.
I am just bolt-ons no engine or valve train mods & at WOT my auto shifts at 6,000. It has been set this way for three years now with no bad effects.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 03-22-2005, 12:48 PM   #11
Originally Posted by slvr2000stang
Not really.
why would you want to raise the rev limiter when the car peaks at 5250-5500 rpms... there is no point for the most part... ive just seen more than one car come in with a rasised or removed (which is REALLY double stupid) rev limiter and expect warranty to cover it lol... either way i guess its just the notion of people thinking the higher in the rpms you go the more power you make, which is of course totaly false, once you peak its all down hill from there, the only reason to go over peak is to boost your next gears rpm (wont drop as low) or to hold a gear at the track to save time that it will take to shift, so you cross the line with out having to shift again.
Old 03-22-2005, 12:55 PM   #12
The only reason I'd want it is just to say I have a raised rev limiter...I never get my car near red lined...just nice to know I can. Same thing with removing the speed limiter, I'll probably never get fast enough to make a difference, but still nice to know I can.
Old 03-22-2005, 10:04 PM   #13
01mineralgrey6's Avatar
yeah, with my bolt ons, 4.10s and that auburn posi, mine woudl burn through 2nd gear and bark 3rd pretty good, youll noitce a i differance in throttle response too. I also picked up som gas mileage when i got mine.
-Tony
'99 cobra 'vert
Old 03-23-2005, 04:10 AM   #14
MonteCitan's Avatar
my chip lowered my rev limiter personally... 6250 stock, 6050 w/chip.. there's no need to go over 6050... no need to go over 5800 RPMs, really.. shifting at 5800 RPMs drops me right back into my powerband...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-23-2005, 08:04 AM   #15
Ever go down the track and miss a shift, hit the limiter, and trash the whole run? Ever spin a little bit and the car revs faster than you expected? Ever spray nitrous, and want a little more safety margin between your shift point and the rev limiter?
justin00stang is offline   Reply With Quote
Old 03-23-2005, 08:07 AM   #16
On the 4r70w 2nd and 3rd gears are spaced very far apart, the rpm drop after shifting into 3rd is pretty bad, setting the 2-3 at 5600-6k helps that.
Old 03-23-2005, 08:09 AM   #17
The chip will work fine.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
Old 03-23-2005, 10:32 AM   #18
Thanks Justin. If I woulda picked this chip up on my way to the meet I would have definitely run.
Old 03-24-2005, 07:15 PM   #19
Well the chip is in now, talk about making a difference. It's like a completely different car. Better throttle response, no more lost time in shifts (up or down), just alot more umph overall. I also found out some things about the chip, it's a SCT tuned chip, but was a diablo blank. I was confused as to how I got a SCT diablo chip lol. But neways, overall, I'm very happy with my 50 buck chip.
Old 03-24-2005, 07:28 PM   #20
hell yeah
-Tony
'99 cobra 'vert
Old 03-24-2005, 07:36 PM   #21
Originally Posted by 01mineralgrey6
hell yeah
Yup yup yup, didn't think a chip would make this much difference.
Old 03-24-2005, 07:49 PM   #22
Because my car like going that hight with it's mods.
The PI woke it up.
2000 Vert 4R70W
Old 03-28-2005, 07:52 PM   #23
MonteCitan's Avatar
told you it makes a difference
Old 03-28-2005, 08:21 PM   #24
Yeh, makes a difference in my wallet too. May be pullling the chip out after this weekend so I can use regular 87 gas again...this premium crap is killer.
Old 03-28-2005, 08:45 PM   #25
timpryor's Avatar
just get it reburned to 87 octane
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 03-28-2005, 08:53 PM   #26
Haha...I'm not spending any more money on this chip. I'll just throw it back in when I actually get a job. Looking for a bike at the moment, so I'll run the chip again after I get something with a little better gas mileage. Can't help but have a heavy foot with this thing in.
performance chip question back-n-black 1996-2004 Mustang GT 4 07-07-2008 10:08 AM
2001 V6 Mustang performance chip question natestang22 Pre-2005 V6 Mustang 4 07-10-2007 05:13 PM
Switch chip question lowflyn Pre-2005 V6 Mustang 7 10-12-2005 01:24 PM
what chip should i use CCstang2004 Pre-2005 V6 Mustang 17 06-30-2005 10:32 AM
chip Sublime782 Pre-2005 V6 Mustang 11 06-09-2005 02:32 AM
03:36 PM
