More info on gears,t-loc, fordchip - Mustang Evolution
Old 08-04-2003, 03:02 PM   #1
Anybody! Im the new guy. I wanna put 3.90s in my 2000 V6 mustang. Should i feel much of a difference? I run a 15.5 now. What shouldi run with gears?
Is the t-loc the same thing as a posi-traction control unit?
Did yall get the fordchip from fordchip.com (should i trust them?)
What is the purpose of the chip?
I need an answer quick cause i wanna hurry and order this stuff and get it installed ASAP, you know what i mean?
Brian
EcalevolBK is offline   Reply With Quote
Old 08-04-2003, 03:51 PM   #2
tire's Avatar
Send a message via AIM to tire
Re: More info on gears,t-loc, fordchip
Ford Motorsport doesn't make 3.90's, but 3.89's are available. However, most would say stick with Ford because their gears are proven. With 3.73's you'd run about 15.0, maybe even break into 14's.
yes.
Did yall get the fordchip from fordchip.com (should i trust them?)?
yes they are trust worthy. pete campbell and jerry run it. there have been past problems of slow shipments of mail order chips, but they are reguarded as the best in the biz.
tune for performance (you can run 91 octane to take advantange, adv. timing, remove speed limiter, move rev limiter, calibrate for new gears.
are you 5spd or auto?
tire is offline   Reply With Quote
Old 08-04-2003, 04:35 PM   #3
Monkey's Avatar
there are no 3.90s for the 7.5 rear end. you have to get an 8.8 and they do make 3.90s... i almost put them in my 8.8 before i got the 4.10s
Old 08-04-2003, 07:11 PM   #4
i have a 5-speed. as far as i know it is a 8.8 rear in the 2000 mustang. can anybody back me up on this?? there are 3.90s made now, they are a new product and they were pointed out to me by a richmond ford mechanic.
Brian
Old 08-04-2003, 07:16 PM   #5
what speed do you top out at with the 4.10s?? which chip do yall recommend (f1,f2,f3,f4)?? will it recalibrate my speedometer?
Brian
Old 08-04-2003, 07:38 PM   #6
tire's Avatar
if it's a stock v6 it has a 7.5 rear end.
a speedcal for 90 bucks will recalibrate your speedo.
the chip is expensive, but you can get just an f1 to fix the limiters and speedo. the speedcal is also adjustable for different diameter tires or different gears.
Old 08-04-2003, 08:39 PM   #7
Monkey's Avatar
your v6 is 7.5... the only 8.8s were in V8s
Old 08-04-2003, 10:16 PM   #8
tire's Avatar
does someone hear an echo in here? i've heard two of them in this thread alone.
Old 08-04-2003, 11:34 PM   #9
Monkey's Avatar
first one i had to correct you, then the second one i was just confirming so he knew you werent wrong again j/k (oh, and the second, i threw in a couple extra bits of info you didnt say... just to help clarify )
Old 08-04-2003, 11:54 PM   #10
tire's Avatar
bah bumbug! .01 diff. !
Trac-Loc wheel hop stangaroo Pre-2005 V6 Mustang 8 11-30-2009 02:04 AM
Changing to a 8.8 trac-loc Sharpie Pre-2005 V6 Mustang 19 08-20-2004 07:09 PM
good place to get 3.73 gears and T-loc for my 7.5 Blue232 Pre-2005 V6 Mustang 4 11-13-2003 06:43 AM
4.10gears/t-loc and speedo. Ginzu Pre-2005 V6 Mustang 2 10-27-2003 07:17 PM
Used factory Ford 7.5 3.73s & T-loc --- Any Good? Stang01 Pre-2005 V6 Mustang 24 07-18-2003 04:40 PM
11:48 AM
