The only adjustment there is for the stock one is to put your foot under it and hook your toe on the underside of the clutch and pull it up, then push it all the way to the floor... It's in the manual.. It doesn't really do squat though. Get an aftermarket quadrant.
a quadrent and firewall adjuster is a double edged sword.... you NEED to keep a certian amount of tension on the cable to keep it from eating up the throw out bearing, stock this is usually WAY off.... if you stick a quadrent adn adjuster in your car and you want a low petal, then it will be a PITA the petal will flop up to the highest point and you will still have to raise your foot up high to get to it, however it will not grab till lower in the cable travel, this will eat up your throw out bearing also due to not keeping the right amount of tension on the cable.
you need to take out ALL the slack so you ONLY have a half inch of play before the clutch petal starts to slip car into neutral, just go down the road at 55mph (hold foot on gas at a constant amount) then push the clutch in, if you push it in a half an inch and the rpms start to jump up then your set, any less than this you need to back it off, any more than this you have to much.
this makes the petal EXTREMLY high... and you will need a maximummotorsport petal height adjuster for 20 bucks to basically move the petal stop down a little bit...
you can adjust the stock quadrent but it sucks... and wont keep the adjustment.
Nah, you can make your own spacers using large washers like I did. My clutch sits even with my brake pedal. All you need to do is use a large diameter spacer to keep the quadrant from allowing the pedal to flop. I still have the washers I used, and I'll throw those in too, if your interested.
you put one washer on one side of the quadrant to hit the pedal stop to prevent the pedal from just hanging there, then on the other side of the quadrant you put another washer of a different size to engage the switch that does things like, shut off the cruise when you hit the clutch or allow you to start the car. Hey... I have a digital camera now... Maybe tomorrow on my day off I can go get a picture of what I did.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
