Ford Chip - Mustang Evolution
Old 05-08-2003, 03:54 PM   #1
Ford Chip
Im getting a ford chip next week. Are they easy to install. After i install it do i need to do anything else. Ive heard alot of people talking about programing them and stuff. whats up with that?
ERICK is offline   Reply With Quote
Old 05-08-2003, 05:09 PM   #2
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Re: Ford Chip
Your ford chip is easy to install. All you need to do is take out your computer and install the chip. There is some goop on the prongs where the chip goes, and you need to clean that off. Ill look for a how-to i remember seeing one somewhere. All that tallk about programming, is probably because ford chip does dyno tunes. They tune the chip so that the car runs the best that it can.
Also you need to test that chip out and see how the car runs, you may need to get it reburned if its incorrect anywhere.
Rellik is offline   Reply With Quote
Old 05-08-2003, 05:49 PM   #3
Ken
Ken's Avatar
Region: New Hampshire
Your computer is on the passenger side, under the kickpanel.
1) Disconnect the battery
2) Remove the kick panel
3) Detach 3 connectors from metal retaining bar, move to the side
4) Remove metal bar
5) Remove bolt holding plastic support for the computer
6) Remove connector from computer, there is a socket to unscrew it
7) Remove computer, take case off
8) Clean connector
9) Remove plastic cap so chip will fit (you will see it when you get there)
10) Clean connector
11) Clean connector
12) Install chip
13) Install case
14) Reassemble
Can't afford Mods? Go To College!
Ken is offline   Reply With Quote
Old 05-09-2003, 01:12 PM   #4
Ken
Ken's Avatar
Fordchip How-To
FordChip Installation Instructions
The instructions that apply to your application will be included with your chip. This is a listing of all the instructions available.Pictures of how the FordChip installs will be posted soon on the pictures page.
Generic Installation Instructions
Installation Instructions for FordChips
1. Remove the negative battery cable.
2. Locate the EEC on your car (since the locations of EEC's vary, we cannot tell you exactly where).
3. Remove your EEC from the car.
4. Remove the service port cover from the back of the EEC. The side opposite the connector.
5. Take a clean rag and remove any grease on the connector.
6. Take some electrical contact cleaner and, while holding the EEC with the service port down,
7. Dry the connector with a clean rag.
8. Take the enclosed sandpaper and sand the service port connectors until you can see copper.
9. Take the electrical contact cleaner and clean the connecter, on both sides, again.
10. Insert your FordChip onto the circuit board connector in the service port.
If you purchased a single chip, proceed to step 12
11. Take the wire with the switch on the dual chip and route it to your desired location
12. Connect the harness, the 104 or 60 pin harness, back onto the EEC.
13. Connect the negative battery cable back on and start the vehicle to verify that your FordChip
14. Install the EEC back into it's location, taking care not to damage or harm the chip on the
15. Drive the car and have fun.
Old 07-15-2003, 12:00 PM   #5
Danger Dude's Avatar
We need updates !!!!!!
Corey
Old 07-19-2003, 11:43 AM   #6
Well after my dyno I have a bad burn on my Fordchip still running very rich. So I have just spent 400 on a dyno session just to find all my problems and now I have to send my chip back DAMN DAMN DAMN ~~
Corey
Old 07-19-2003, 12:03 PM   #7
slvr2000stang's Avatar
Corey,
$400?? wow. how many runs? What all di you get?
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 07-19-2003, 12:19 PM   #8
10 or 12 and 4-5 hours of testing and diagnosis we did all types of test compression, ignition heat rang test, A/F test, O2 sensor test, vacume test. Hell we even test the test. We had one cylinder showing about a 80* difference and found 5 hp by just changing that plug.
Corey
Do you need a chip? snydermj 2005-2010 Mustang GT 16 09-11-2009 06:54 PM
what chip should i use CCstang2004 Pre-2005 V6 Mustang 17 06-30-2005 10:32 AM
f2 chip ttpancakes Pre-2005 V6 Mustang 3 07-07-2004 10:46 AM
Ford CHIP starboarder2004 Pre-2005 V6 Mustang 15 01-19-2004 11:19 PM
08:19 PM
