8.8 From a Crown Victoria - Mustang Evolution
Old 03-27-2005, 09:27 AM   #1
clutchsix's Avatar
Ive been looking for an 8.8 Rearend or a 7.5 Traction-Lok unit. I found an 8.8 Rearend off of a Crown Victoria with a 28 Spline. My question is, will it fit on a Mustang that is also a 28 Spline. I thought all Ford 8.8 rearends were interchangable with other 8.8 rearends with the same Splines. Someone told me it wouldnt fit a Mustang because the Crown Victoria has different mounting points? Would it fit on a Mustang.
clutch
n.
1. Control or power.
2. The crucial moment that comes between winning and losing
3. Something that is really sweet.
http://img.photobucket.com/albums/v6...0Pics/sig2.jpg
clutchsix is offline   Reply With Quote
Old 03-27-2005, 09:35 AM   #2
I Am Pretty Sure The Internal Assembly Will Fit, But The Housing Wont Mount To The Mustang.
Old 03-27-2005, 09:36 AM   #3
clutchsix's Avatar
so what would have to be done to make it fit? or should i not even bother in getting it.
clutch
n.
Old 03-27-2005, 09:38 AM   #4
since the crown vic has a completely different chassis, you would have to do alot of fabrication to make it fit. with the time and money you spend on the crownvic rear end you could have just payed for an 8.8 out of a mustang.
what are your plans as far as power? it could be that you dont need an 8.8.
Old 03-27-2005, 09:43 AM   #5
clutchsix's Avatar
Well as far as future plans, i donno if im gonna add any power adders, if so it would only be nitrous (like a 75 shot). Im getting all of the bolt on's as well. 7.5 rearends are weaker than 8.8s. Also if i can just find an 8.8 rearend from a Mustang, it already has the Traction-Lok. I just want to get the 8.8 incase i do anything serious to it. Its hard to find a cheap 7.5 T-Lok unit as well.
Thanks for the info about the Crown Vic.
clutch
n.
Old 03-27-2005, 09:49 AM   #6
here is my suggestion, since you dont plan on big power, get an auburn limited slip diferential for your 7.5 and get ford racing gears. since the weak part of the 7.5 is the spydergears the auburn will take care of that. and it will cost less than installing an 8.8.
Old 03-27-2005, 09:53 AM   #7
clutchsix's Avatar
How much would you think it would all cost to buy, not to install? Are you sure it would be less than installing an 8.8?
clutch
n.
Old 03-27-2005, 10:00 AM   #8
yeah it will be less than an 8.8 it will be about 500 for parts.
Old 03-27-2005, 10:06 AM   #9
are you asking if the t-lok from the crown vic will fit an 8.8 rear end that has been taken off a mustang or are you asking if the housing will bolt to a mustang
like are you saing if it will fit in here
or are you asking if the whole unit will bolt onto a mustnag chassis.
1994 Crown Vic v8 4.6l to 1996 mustang v6 djcb3man2001 1996-2004 Mustang GT 0 01-17-2009 04:28 PM
Photoshop_Ford Crown Victoria mustang 4 life Pictures and Videos 1 07-12-2008 10:35 AM
CROWN VIC SELL fsst93gt Mustang Parts for Sale and Wanted 0 02-04-2006 04:59 PM
2002 P71 Crown Vic FS Fishers Stang Mustang Parts for Sale and Wanted 21 05-03-2005 09:22 PM
09:02 AM
