temp. guage question - Mustang Evolution
Old 03-28-2005, 03:01 PM   #1
red pony V6's Avatar
Send a message via AIM to red pony V6
i think my temperature guage is acting up. every once in awhile the needle will go all the way to the HOT side, then after a few minutes it will go back to normal. the first couple of times it did this i pulled over to check my fluids and i even felt the engine to see if it was unusually hot and everything seemed fine. does this sound like a problem with the guage or some kind of sensor? or should i be worried that the engine really is overheating? i just don't know why it would go back to normal for no reason.
1998 V6
true dual flows
CAI
MGW shifter
and slow as hell...
red pony V6 is offline   Reply With Quote
Old 03-28-2005, 03:09 PM   #2
MonteCitan's Avatar
technically the engine won't be any hotter with the gauge all the way up.. the coolant will be..
you might have a failing tstat... ... any way you can get someone to view live data for you? that might give away if its the thermometer, thermistor, whatever..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-28-2005, 03:09 PM   #3
the stock gauge blows anyway... you may want to get a autometer gauge to keep an eye on the REAL temps perhaps pull the dask and inspect the plug in behind the gauge, it may just be getting old, also check to make sure the needle is on good DONT pull it off though.
Old 03-28-2005, 06:35 PM   #4
Ponycarman's Avatar
Almost everytime I've had a flaky temp reading it's been the sending unit not the guage.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 03-28-2005, 06:56 PM   #5
yup, definatly didnt even cross my mind though... probably the sender, its easy to get to... ..... not really bad at least its on the front of the motor at the front of the upper intake.
Temp Gauge not working? BILLFORD01 1996-2004 Mustang GT 5 08-06-2009 11:04 AM
Guage Cluster V6 to GT 02V6TTcoupe Pre-2005 V6 Mustang 7 08-28-2006 11:28 AM
Decided to keep Water Temp Guage Ibanezplayer272 1979-1995 Mustang GT 2 02-04-2006 04:52 PM
05 guage cluster natebest2000 Mustang Audio & Video 9 03-01-2005 10:51 AM
Help...Temp Black95GT Pre-2005 V6 Mustang 8 02-18-2004 10:35 AM
08:17 AM
