Higher RPM's Due to Electrical Load? - Mustang Evolution
Old 03-29-2005, 04:56 PM   #1
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Ok, put your thinking caps on.
I usually dont pop into electronics, but since a question arose, I've been wondering myself as the possible cause and or solution.
The electrical load on a car is never constant, it varies with lights being on, fans, your RPM's in relation to your spark plug firing speeds, your stereo system, ect.
My question to you all, will a higher amount of load cause your computer to increase the RPM's at idle to keep an adaquate charge output?
A few times, a question about Cold Air Induction mods would come up stating that the RPM's are higher at times. The only thing that I've found that were in common with most of them, was that they had either their heater on full blast, or their A/C on.
Would the heater core and the fan create enough of a load on an engine to make the RPM's raise higher than normal? I know the AC usually will increase the RPMs only because of the extra load it puts on the belt (the comptuer is attempting to keep the idle up with the extra load). Since electric motors are considered to be one of the highest electrical hogs in the electronics world, I would assume that COULD be a possibility.
Any ideas? Am I even in the right ballpark?
Thanks guys!
Rellik is offline   Reply With Quote
Old 03-29-2005, 05:16 PM   #2
Fishers Stang's Avatar
idk, but on my Vic it has a high idle setting due to the power load it has. but on the stangs, i have no idea
Charles
Old 03-29-2005, 05:18 PM   #3
01mineralgrey6's Avatar
i don't know either
-Tony
'99 cobra 'vert
Old 03-29-2005, 05:41 PM   #4
I know when I run my subs full blast...my car idles higher. I'm also pulling about 1000 watts of constant power then...so that may have something to do with it. I'm gonna kill my alt, but that's ok, won't be my first to kill lol
Old 03-29-2005, 06:15 PM   #5
Hmm... I seemto have asked aquestion that NO ONE knows the real answer to.
I guess it was a good question then
Still waiting on logical answers.
Brad, your statement only strengthens my intreptation of the electrical load vs. RPM's.
Old 03-29-2005, 06:45 PM   #6
"Engine, gasoline, 4.6L overhead cam, SEFI V8, unique with Police Pursuit calibration including increased idle speed for improved charging system output and cooling"
"Alternator, heavy duty 135-amp maximum output, 82-amp at idle w/unique drive pulley for improved charging system" (https://www.fleet.ford.com/downloads...ice/police.pdf) so i still dont know. EDIT* thats on my 02 P71 Vic
Charles
Old 03-29-2005, 07:25 PM   #7
Tbird232ci's Avatar
with the a/c example, the idle speed is increased, and a few other things change, such as in some cases, the timing will get retarded (in dodges, not sure about ford), and the electric fan will be kicked on if so equipped
with my cars, the more stuff i turn on, the car bogs, ive had cases where my 3.8 car actually stalled when i had the heat, my lights, and my sub on, but if i increased the idle myself, no problem
as we know, with electric motors, they have an effeciency range, an alternator is an electric motor, but that produces power, and even at idle, its out of its effeciency range, i believe even 120amp alts only put out 60amps at idle
as for the idle increase, i personally think its because when the idle drops because of the extra load, the EEC see's that, and increases the idle, only because it see's the dropping idle as something it needs to adjust, not sensing the electrical load, the car will strive to keep a certain idle, and any variation (within reason), it will try to compensate for, and thats just one of the cases
Old 03-29-2005, 07:45 PM   #8
wiarumas's Avatar
hmm ya learn something everyday.
Old 03-29-2005, 07:54 PM   #9
MonteCitan's Avatar
yes, it does.. your car is smarter than you think.. if it's reading an amount but its not within range, it'll do whatever it can to get back in that range.. that's why when you first flip your headlights on, your idle dips then readjusts... with much heavier loads it can definitely ramp the idle up..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-29-2005, 08:20 PM   #10
I think my alt is going out..my headlights have been dimming while stopping here lately...like noticably
Old 03-30-2005, 08:41 AM   #11
On most Fords here's how it works.
Often there is an idle speed adder when you flip the AC on, the computer will raise idle speed 50-75rpms. This is to get a little bit more power out of the alt (to run the engine fan for the condenser and to run the blower fan for the interior), the ac compressor works a little better at higher RPMs, and in some cases to make the engine run smoother with the increased load of the AC compressor.
Increasing load on the alternator does put more drag on the engine, but there is no seperate logic to account for this other than the computers built in ability to control idle speed. It uses a PID type algorithem to learn and adjust the amount of air (through the IAC valve) to keep the engine at a given idle speed. If your idle speed gets higher with a lot of electrical load then its just the computer overcompensating and adding too much air, over time it will learn back down to the normal idle speed.
The computer does try and compensate when the engine fan kicks on. The fan draws so much power (over 30 amps) that it will cause a noticeable dip in idle. There is an air adder (through the IAC valve) that adds in air whenever the computer commands the fan on, this is to keep the idle speed constant and prevent a large dip. You'll probably still feel it anyways to a small extent.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 03-30-2005, 09:45 AM   #12
Thank you gentlemen, you adaquately answered my question to a satisfactory degree
rpm's for gear ratios chart Herbstang The Bar 10 06-21-2007 03:23 PM
Cop Blows Load on Stripper bluemustang The Bar 6 02-27-2007 12:58 PM
Feedback on site load times Brent The Bar 20 04-12-2006 08:27 PM
RPM's top out at 3,000 stangracer 1979-1995 Mustang GT 11 06-02-2005 01:20 PM
11:36 PM
