H or straight ? - Mustang Evolution
Old 03-30-2005, 07:55 PM   #1
TNT Bomb's Avatar
H or straight ?
What will be the difference in sound or performance if I put a steeda adapter or I weld the GT Takeoffs straight true duals without any H (in both cases I remove the Y and I keep the stock cats) ?
http://www.mustangevolution.com/foru...ine=1111897454
2004 V6 Engine 5 spd
TNT Bomb is offline   Reply With Quote
Old 03-30-2005, 09:01 PM   #2
Performance, none, the 3.8 V6 is an even firing engine, not needing a H/X pipe to equalize pressure from side to side.
Now then...sound. This is a debate that has gone on forever and will always continue. Some ppl say a H-pipe will give you a deeper sound than true duals. But...I don't notice this difference in sound. I have my exhaust (mach 1 takeoff's) run true duals, and I love the sound (just slightly louder and deeper than gt takeoff's). If it was me, I'd say go with the true duals.
Now that I actually read your post...I see that you wanna know the difference in sound between using a steeda adaptor and just welding the takeoff's straight up. The only big difference I can think of, is if you ever wanna take your exhaust off, the steeda adapter will work best. Running true duals, welding them right up (as I have my car done) is the cheapest way to do this by far....but whatever you really want to do man.
Old 03-31-2005, 10:18 PM   #3
TNT Bomb's Avatar
Thank you very much for your advice, I'll make them weld, I don't think I'll have to remove them until the date I'll change them and as the Takeoffs are in stainless steel they will last for a long time (I hope...)
Old 04-01-2005, 08:29 AM   #4
Good deal man.
Old 04-01-2005, 10:37 AM   #5
my car has true dual exhaust but it has no mufflers but it still has 2 high flow cats. It sounds really good at idle and until around 2500 rpms but after that its all ricey from there. but i just recently purchased a new cam and heads for my car so that will help the exhaust sound. it will sound more like a v8 now but as everyone knows the only way to sound like a v8 is to have a v8.
bigpomps is offline   Reply With Quote
Old 04-02-2005, 12:43 PM   #6
RGR
Send a message via AIM to RGR
Originally Posted by bigpomps
... but as everyone knows the only way to sound like a v8 is to have a v8.
how true!
I like X pipes myself, but the guys are right, probably no gains from using it at
all. I'd use it for sure if you generate alot of exhaust (like a stroker, SC or NOS)
but an NA 3.8 probably is fine with straight duals. (no crossover)
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
more power from 200 straight six maxxx Classic Mustangs 1 03-31-2009 08:18 AM
Straight or 90 degree scroll Falcon General Car Discussion 9 03-19-2007 07:47 PM
straight up gangsta yo! whipster24 Pictures and Videos 20 03-30-2006 05:57 PM
Jealous? Damn straight! Seph The Bar 29 10-10-2004 04:06 PM
straight pipes STEVE Pre-2005 V6 Mustang 52 06-20-2004 10:09 PM
02:41 PM
