Camming a 3.8 - Mustang Evolution
Old 07-06-2009, 08:50 PM   #1
Camming a 3.8
has anybody thrown a new cam into their v6? when i rebuild i am planning on putting a tom morana cam, heavier springs, stronger pushrods, and new pistons. How effective are new cams in v6's? horsepower addition estimation for just the cam alone?
Brett09 is offline   Reply With Quote
Old 07-06-2009, 09:36 PM   #2
Re: Camming a 3.8
The cam alone is not going to net you that much. Do some work to make the cam work better (move the air in and out more efficiently) and the gains will be much greater.
Old 07-06-2009, 10:47 PM   #3
Re: Camming a 3.8
well im on a tight budget with no roo for a new intake manifold or power adder, as it turns out i may not b able to do the rebuild that needs to be done, the car is 13 yrs old and i have no idea how it has been treated, it is a 5-spd so im sure sumwhere along the line its been abused, so im not sure wut to do on more airflow for theamount of money i may
Old 07-07-2009, 01:23 AM   #4
RyansQuick6's Avatar
Re: Camming a 3.8
Don't buy anything from Tom Morana, ever.
You're better off doing a split port swap, you'll see an instant 40hp.
RyansQuick6 is offline   Reply With Quote
Old 07-07-2009, 07:47 AM   #5
Re: Camming a 3.8
yea instead of a rebuild you could buy a 99+ 3.8 for quite cheap, but you will need the fuel system and wiring setup and computer etc to make it all work
Old 07-07-2009, 01:06 PM   #6
Re: Camming a 3.8
i dont rlly want to do a motor swap though, id rather do a rebuild that way i get a brand new motor basically, plus i would basically have to do a rebuild to put the new cam, springs, pistons, and rods in so theres not rlly much point in doin a motor swap.
wut is wong with doing tom morana parts?
Old 07-07-2009, 05:36 PM   #7
Re: Camming a 3.8
Go to some of the v6 stang sites and mention his name and you'll find out. You're best bet is Tom at SSM.
Old 07-07-2009, 05:38 PM   #8
Re: Camming a 3.8
haha ill pass on that idea, i was just curious as to wut kind of probs people have had out of him
Old 07-08-2009, 10:30 AM   #9
Herbstang's Avatar
Re: Camming a 3.8
Gotta agree !! Ever since Mik closed shop Tom Y is the man
Old 07-16-2009, 10:31 PM   #10
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: Camming a 3.8
I miss Mik. I'm pretty sure I got the last, if not the only stage 3 CNC big valve heads from him just before he quit.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
camming my 02 v6 tigerfan2771 Pre-2005 V6 Mustang 1 03-24-2008 07:16 AM
99^ split port camming and tune dyno results... (NO PORTING!!!) RGR Pre-2005 V6 Mustang 6 04-09-2004 07:07 AM
10:22 PM
