Idle problem - Mustang Evolution
Old 07-10-2009, 10:57 AM   #1
McGrail482's Avatar
Region: West Virgina
Send a message via AIM to McGrail482
Idle problem
I have a new IAC ordered that I am going to pick up after work because of my idle problem. It sits at 500 rpm and when i turn on the A/c or turn the wheel the rpm's drop down below 500 and it seems like the car starts struggling. When I unplug the IAC it runs for a minute then dies, and wont even start with it unplugged. Does this sound like the IAC cause i really dont wanna have to spend 60 bucks for a new one if thats not it. BTW it isnt throwing codes anymore since I replaced the maf sensor.
-Jason
2015 5.0 Mustang
Previously Owned:
1995 3.8 V6 Mustang-True Duals w/Mac Flowpaths, BBK CAI
2012 Ford F150 FX4
McGrail482 is offline   Reply With Quote
Old 07-10-2009, 01:44 PM   #2
Herbstang's Avatar
Re: Idle problem
Sounds like it !!! Have you tried cleaning the IAC when you did the MAF
try this to determine if the IAC is bad, start engine, place in gear (drive, Reverse), turn A/C on, and operate the power steering pump (turn wheel slightly right or left). the rpms should increase slightly or remain steady, if it drops or stumbles then the IAC is bad and need to be replaced.
Old 07-10-2009, 02:35 PM   #3
McGrail482's Avatar
Re: Idle problem
Yes i have cleaned it but from my understand in doing research on them, cleaning them doesn't work in most cases and if it does it is short lived. Guess im going to buy a new one
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 07-10-2009, 02:43 PM   #4
Re: Idle problem
my grounding was bad to the same issue i dont know why but since i replaced it ive had little to no problemns except that one time whith the bad pilot bearing not throw out bearing!
dalltx is offline   Reply With Quote
Old 07-13-2009, 09:56 AM   #5
McGrail482's Avatar
Re: Idle problem
Put in the new iac and in park it will idle at about 600 but when I put into drive it drops down below 500 and jumps back up and sits at 500 again.
When i first installed the iac it seemed back to normal (idleing at about 750) but over time it went back to its old ways, is there a special way that i need to have the computer relearn an idle?
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Erratic Idle problem solved-Intake manifold vacuum leak Mercedez L. 1979-1995 Mustang GT 7 07-30-2010 09:08 AM
Idle Problem Help!! W225110 1979-1995 Mustang GT 7 03-30-2010 07:12 PM
Doesn't idle down. Joe_SHO Pre-2005 V6 Mustang 7 02-12-2009 07:44 AM
94 3.8 off idle hesitation problem crash Pre-2005 V6 Mustang 3 07-14-2008 06:19 PM
At idle ASSEMbler Pre-2005 V6 Mustang 14 08-07-2003 01:54 AM
03:39 PM
