gears and tlok - Mustang Evolution
Old 04-11-2005, 03:23 PM   #1
1997grnstang's Avatar
Send a message via AIM to 1997grnstang
gears and tlok
ok guys, Ive finally put aside enough money to purchase some gears and tlok. I bought 3.73 gears, tlok and some friction modifier from gefracing.com. Im thinking about buying a Speedcal to fix the speedo problem. So is there anything else I need before I take it to get installed?? Ive heard something about an install kit?
Thanks
-John
http://www.mustangevolution.com/gall...oveoneclub.jpg
My Car
1997 Pacific Green Mustang
5-speed
1997grnstang is offline   Reply With Quote
Old 04-11-2005, 04:41 PM   #2
01mineralgrey6's Avatar
i would reccommend the install kit, basically it has all new bearings and stuff.
-Tony
'99 cobra 'vert
Old 04-11-2005, 04:56 PM   #3
wiarumas's Avatar
a camera.. for pics.
Old 04-11-2005, 05:29 PM   #4
your car is 8 years old so you might aswell get the install kit and get all the bearings and seals.
Old 04-11-2005, 07:11 PM   #5
douGT's Avatar
hey guys, i am about to buy 3:73's for my car also, so would i have to get anything else for with that, etc.
douGT is offline   Reply With Quote
Old 04-11-2005, 07:32 PM   #6
your car is farely new so a basic install kit will work for you.
Old 04-11-2005, 07:37 PM   #7
douGT's Avatar
alright, another question, are these really hard to install??
Old 04-11-2005, 07:44 PM   #8
an isntall kit is really only bearings, the gears have shims with em so .... pretty much all you need to get is bearings and seals which is a great idea...but not needed, i would replace the pinion seal, the seal on the axle ends, and you will have to buy bearings of course... these parts are pretty cheap, 75-90 bucks for everything. What ever you do get a QUALITY install... when you shop around, and do shop around some places will rip you a new one, ask about back lash, pinion seal depth setting, how do they set the crush sleve, wear patterns... and a warranty for breakage due to install issues (loose ring gear bolts) and gears are KNOWN for whinning...(due to the back lash and other items not set with in tollerance)....
things can just get annoying and if you do get lower control arms in the future these noises will be amplified... or become noticable... not trying to scare you just be careful who you get to do it... even if its a rip off if you can get a quality job done for 200 bucks more... pay it having a pre 99 i would send all the stuff back and buy a pre built 8.8 rear for 725.00 reuse your stock axles (just pop em in) and then bolt the rear in, put some fluid in it and drive all in all have 800 invested in a 8.8 AND a spare 7.5 to sell for 200~ bucks or to keep for when you need it down the line.
Old 04-11-2005, 07:44 PM   #9
yes, it is everything is critical, but you CAn do it with the right tool, in my sig there is a link where it says, "and here" in the tech links click that and it will take you to an install write up.
Old 04-11-2005, 09:52 PM   #10
any good places to buy an install kit?
My Car
5-speed
Old 04-11-2005, 10:15 PM   #11
well you pretty much just need bearings and seals, I think gefracing.com has a kit but just call ford see what they charge.. probalby will be more but heck give it a shot and factor in shipping on that price quote also.... Open your gears see if you have shims with em.
Old 04-11-2005, 10:15 PM   #12
stangsuspension.com or gefracing.com
Old 04-11-2005, 10:17 PM   #13
check both, also check summit they price match and may offer free shipping.
You CAN install it all yourself, the install is actually very simple.. its the little details that will screw you over... you have to check a good bit of stuff and do it RIGHT this is why most shops wont do it.... or they charge you FAR to much to do it... or they just half *** it.
Old 04-11-2005, 10:25 PM   #14
thanks
My Car
5-speed
Old 04-11-2005, 11:03 PM   #15
FloMasta24's Avatar
Send a message via AIM to FloMasta24
where can you get a pre built 8.8 that sounds a lot better then the other way and it costs like the same I might be doing that
1998 3.8L Mods: CAI, Flowmaster dual exhaust with H-pipe, Black Cobra Style headlights, Racer's Choice short shifter -SOLD!
Now cruising in an '03 Nissan Spec V w/ intake and exhaust-hell yeh
Originally Posted by Seph
vday is like an srt4, at first it sounds good and in the long run it sucks
FloMasta24 is offline   Reply With Quote
Old 04-11-2005, 11:10 PM   #16
speedconcepts.net
tlok,3.73 gears. no tune? DEG Pre-2005 V6 Mustang 8 11-16-2009 08:07 AM
Performance Chip or Gears/TLok... which one? AirBrontosaurus Pre-2005 V6 Mustang 10 02-21-2006 10:17 PM
Want 3.73 gears and tlok ttpancakes Mustang Parts for Sale and Wanted 4 08-15-2004 02:36 PM
WTB gears, tlok 04V6STANG Mustang Parts for Sale and Wanted 4 03-09-2004 07:35 AM
Gears and tlok speedo correct Falcon Pre-2005 V6 Mustang 15 12-21-2003 07:54 PM
04:46 AM
