o2 Sensor problem - Mustang Evolution
Old 07-13-2009, 10:27 PM   #1
o2 Sensor problem
I've had my exhaust for about 3 weeks or so, and already one of the oxygen sensors has messed up. Would I be better off just cutting the o2 sensors and the cats out or just replacing it?
19Delta is offline   Reply With Quote
Old 07-13-2009, 10:33 PM   #2
Re: o2 Sensor problem
What exactly is the problem? If you are trying to still run rear 02 sensors with an o/r pipe you'll never find a set that will make it.
Old 07-13-2009, 10:35 PM   #3
Oh, ok. Problem solved then, thank you. I'll go sometime later this week and get them cut out and get the code removed.
Old 07-13-2009, 10:56 PM   #4
You have two choices with this really....
MIL Eliminators (you plug this connector into the factory rear o2 harness and it tells the computer they're ok)
Have a custom tune turn off the rear sensors.
There are backwoods fixes to this...but I do not condone these. They require a skilled welder and a good stick.
Old 07-17-2009, 01:51 PM   #5
Ok, where's the best place to get a set of MIL Eliminators? I tried auto zone but I'm thinking this is a specialty product and you can only order it from an online store.
O2 SENSOR redGT773 2005-2010 Mustang GT 21 01-29-2009 01:17 PM
M.A.F. Sensor 03GTNEWB 1996-2004 Mustang GT 5 07-15-2008 11:45 AM
o2 sensor Mustang414 Pre-2005 V6 Mustang 0 05-18-2005 08:36 PM
O2 Sensor Out. Dom Pre-2005 V6 Mustang 18 12-18-2004 07:58 PM
DPFE sensor MUSTANGJUNKY420 Pre-2005 V6 Mustang 3 08-01-2003 09:15 PM
06:01 PM
