07-14-2009, 03:07 PM
#1 | | Registered User
| Posi and Gear
05 Stang - I'm looking for some more performance upgrades without going to F.I., got the tuner, CAI, exhaust, now I am unsure where to go next, wondering if anyone has their diff. upgraded by a shop and how much were the labor costs for such this job. If I was to go with a posi w/ 4.10 gears
07-14-2009, 03:18 PM
#2 | | Terminator Owner
| Re: Posi and Gear
labor will run you about 200-500 depending on shop
__________________ 2003 Cobra Vert (Redfire) #3938 of 5082 @ 05/27/2003
472rwhp/493rwtq - Modification List - Dyno Sheet 2012 Mustang 3.7L M6 (Kona Blue) 2011 Ford Edge Sport (Red Metallic) |
07-14-2009, 03:23 PM
#3 | | Registered User
| Re: Posi and Gear
And that's for adding the posi and gear setup, wow if that is the case, then that's better than what I thought
07-14-2009, 03:48 PM
#4 | | Registered User
| Re: Posi and Gear
Cost me just under $900 to buy both and have the installed on my 07
2007 V6 Mustang w/ Pony Package. Performance Mods - 2.25 custom aluminum catback exhaust with a Magnaflow muffler, AirRaid cold air intake, drilled and slotted rotor's front and rear, SCT Programmer, Ford Racing Tlok, Motiv 4:10 gears, LFP underdrive pulley
07-14-2009, 03:56 PM
#5 | | Registered User
| Re: Posi and Gear
Just to be positive, I need the t-lok, pinion and ring, bearing set. Anything else I have to buy for someone to change this out.
07-14-2009, 05:23 PM
#6 | | Registered User
| Re: Posi and Gear Quote:
Originally Posted by obxdude018 Just to be positive, I need the t-lok, pinion and ring, bearing set. Anything else I have to buy for someone to change this out. | the only other thing would be new fluid, but that's it. any shop around should be able to order and install the stuff for under $1,000.
1970Chevelle SS 454 big block Old School 500hp Sold |
07-15-2009, 05:35 PM
#7 | | Registered User
| Re: Posi and Gear
What recommendations on brands should I go with.
07-15-2009, 06:45 PM
#8 | | Registered User
| Re: Posi and Gear
For fluid, royal purple friction modifier is good.
You can get it on American Muscle.
07-15-2009, 08:54 PM
#9 | | Registered User
| Re: Posi and Gear
i bought rings and pinion on ebay for $164 install kit $94 and American Mussle has a tech section that shows step by step i'm starting mine myself tomorrow.
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
07-16-2009, 08:52 PM
#10 | | Registered User
| Re: Posi and Gear
^^^You have the proper tools to set backlash and adjust shim thickness.
07-17-2009, 02:20 AM
#11 | | Registered User
| Re: Posi and Gear
yes with the write up it shouldn't be that bad
07-17-2009, 10:32 AM
#12 | | Legacy Member
Originally Posted by 2007STANG yes with the write up it shouldn't be that bad | Yeah let me know how that turns out !!!!
do you have a 2/3 jaw slide hammer to remove the axles bearings/ bearing races for the pinion gear ???
a hydraulic press for the carrier bearings ????
disk brake tool for depressing the caliper piston ??
There's alot of things required like a 3 to 4 foot extension for the breaker bar to turn the pinion nut and good luck setting the preload on the bearings via the crush collar the amount of torque required to crush the collar is huge and if you **** it up you'll need a new collar
here's a tool list
Dial indicator
Gear marking compound and a clean brush
Calipers or a micrometer
Bearing pullers
Bearing press
Three foot long breaker bar or strong impact gun
Pinion nut socket
Ring gear bolt socket
Carrier cap bolt socket
Six point cross pin bolt wrench
Brake line wrench
Pry bars for removing the carrier case
24 oz ball pein hammer
48 oz sledge hammer
48 oz plastic dead blow hammer
Assorted brass punches
Punch for marking carrier caps
Oil drain pan
Foot pounds torque wrench
Inch pounds torque wrench
Mods-K&N CAI , True Dual Flowmaster 40,BBK Ceramic Shorties,3.73 ,T-Lok, 25% UDP, 3/8 Phenolic Intake Spacer ,Steeda Tri-ax, SCT Chip/Dyno Tune Quote: |
07-17-2009, 03:49 PM
#13 | | Registered User
| Re: Posi and Gear
check all here
07-17-2009, 07:59 PM
#14 | | Registered User
| Re: Posi and Gear
well then, good luck to ya
definitely tell us how it went...
07-17-2009, 09:31 PM
#15 | | Registered User
| Re: Posi and Gear
I did it myself.... It was pie.
