Bought a summer ride..'96...a few questions - Mustang Evolution
Old 04-12-2005, 11:47 AM   #1
I just bought a companion to my 03.A 1996 v6 Stang convertible,auto trans.I haven't done a whole lot of research yet.I know the car was originally sold in California when new.Does that mean it'll have a smog pump on it somewhere?
Also,are there any well known bugs about this year I'll need to know about?It has 112,000 miles.Very clean,runs out nice.Can't wait to put the top down and cruise!
Ghostbuster is offline   Reply With Quote
Old 04-12-2005, 11:59 AM   #2
Not sure if the smog pump thing was only on 99+ but i am pretty sure you have it also.... the only known bug for that year that is really worth looking into is a potential head gasket issue, mid 96+ they fixed it... so check your vin to see if it was fixed, maybe you got lucky it needed it and ford put a new motor in her they have been known to do that... if its not been fixed then your own your own the recall was only for 7 years.
Old 04-12-2005, 12:29 PM   #3
SpectorV,thanks.It was made in 2/96 so I guess I'll be hoping the gasket was changed
out.The paint code appears to be rc.Know what that is?Its some sort of metallic red.
Old 04-12-2005, 12:35 PM   #4
if its a darker red its most likly lazer red.. not a cheap paint job there lol, rio red is the brighter red for that year.
Old 04-12-2005, 12:53 PM   #5
Yes,its almost a cranberry like metallic.I'm not a big fan of red but it does look nice.
Old 04-12-2005, 02:48 PM   #6
I liek gramer
WhiteStang99's Avatar
I had a laser red 97 once.
Old 04-12-2005, 02:54 PM   #7
you dont have to lie to have friends/fit in, but it helps
Old 04-12-2005, 02:55 PM   #8
I liek gramer
^ haha, except I'm not lying. I liked the color.
I traded it in for a telephone pole though. If any of you ever get that opportunity, DON'T TAKE IT!
Old 04-13-2005, 06:40 AM   #9
A few obserservations I 've made:The car appears to be 100% original.The spark plug wires look to be as old as the car,I'll change them out.Also,it needs a flush and refill for the coolant.
The car was owned by a couple in their mid sixties....get this..they traded it in for an 05 Mustang, lol!!Gotta love it.Oh yeah,the interior is nearly perfect.I think I'm gonna like this car.
I had no plans of buying this,but when I saw it I couldn't resist.I think I'm having a mid-life crisis!!
Old 04-13-2005, 09:56 AM   #10
mydi777's Avatar
Send a message via Yahoo to mydi777
LOL, Congrats on the Stang!
BTW Mustangs weren't the only 94-96 Fords with head gasket problems! My 96 Windstar blew a head gasket for no aparent reason last year! It has a 3.8 V6, and at time it had about 120,000 miles on it. $1000 to fix
It might not be a bad idea to have it checked out just in case!
http://www.mustangevolution.com/foru...ine=1110463871
My Car
1998 3.8 V6, Flowmaster True Dual Exhaust
mydi777 is offline   Reply With Quote
Old 04-13-2005, 10:27 AM   #11
Danger Dude's Avatar
Exactly all 3.8's up to mid 96 had head gasket problems except the Thunderbird SC and that is where they went to fix it. The quick fix was to put on a Sc head gasket and in 96 sometime they had a new head similar to the Sc head. The cooling passages in the pre96 were designed to close to the cylinder wall and the gasket originally used deteriorated and blew
Old 04-13-2005, 10:32 AM   #12
slvr2000stang's Avatar
Ragtops Rule!
Check the level & color of the trans fluid if it looks ok and there are no shifting problems, that's good. Then maybe just the usual, oil change etc.
Might also want to change the fuel filter.
What color is it?
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 04-13-2005, 10:37 AM   #13
I don't know the color exactly.All the stickers and vin numbers match..but...the paint code doesn't.I went to the autozone,they said my code is for tan or silver????
If this car has been repainted whoever did it was a total pro.Its a cranberry looking metallic,thats all I can tell right now.The top is white.
Old 04-13-2005, 10:55 AM   #14
I am pretty sure it is not Laser red then Because it is a tri color like Mystic. You have to paint a copper base, then a Pearl, then Rose or Rose then Pearl. The cost of the Tri color paint and thinners can cost up to $1,400 alone.
Old 04-13-2005, 11:55 AM   #15
DD,do you happen to know the code for laser red?The car also has thin white pin-stripping but I'm guessing thats not original.
Old 04-13-2005, 12:19 PM   #16
E9 is the Laser Red code and mine came with a thin white pin stripe on the upper door
Old 04-13-2005, 12:37 PM   #17
I think I was looking at the wrong letter and no. as there is an E9 on the sticker.So now I know the color at least.Thanks.
Old 04-13-2005, 12:42 PM   #18
Cool. Glad I could help
Old 04-16-2005, 04:12 PM   #19
Here's a bit of an update...
Took it to have the coolant flush/refill and install a new drive belt.They looked it over.The mechanic said its in very good condition, age and mileage considered.It appears to have been very well cared for,and has new struts on it.
One disheartening thing though.Upon close inspection rust has just begun to form a little at the bottom of the door panels.I'm in Ohio...that means ice,snow and road salt.In my experience this type of rust is hard to stop,usually spreads like wildfire.
Thing of it is I really like this car,but it'll be expensive to have this taken care of.
GTO is over this summer Dark02Pony The Bar 9 02-23-2006 10:56 AM
How many are about out of school for the summer? SpectorV The Bar 25 05-01-2005 12:53 AM
Over the summer..... damustangfan14 The Bar 8 08-02-2004 07:25 PM
We should all meet up this summer! MusclesFromBrussels The Bar 17 10-16-2003 06:54 PM
hello....summer? Rellik The Bar 18 08-04-2003 04:48 PM
11:43 AM
