07-18-2009, 08:25 PM
#1 | | Registered User
| Which engine to use :-)
I bought a 1994 Mustang convertible about 2 years ago. It had a V6 in it that was blown up. About a year ago, I bought a 1988 Crown Vic for the engine (302) with plans to convert it from fuel injection to carberuetor and put it in the Mustang. Took several months to gather the parts I need. Now, I have most of the parts and was getting ready to install the new engine and ran across a deal on a 1997 Mustang GT that had been wrecked, but has a 4.6 SOHC (rebuilt, bored 20 over). Have been contemplating putting that one in the 94 convertible. Today, I found a 1986 5.0 HO in a GT T-Top (couldn't buy the entire car because there was no title  ) . So now, not sure which direction I want to go with the engine swap on the convertible. Thoughts anyone?
__________________ |
07-18-2009, 09:23 PM
#2 | | Registered User
| Re: Which engine to use :-)
carb'd 302 or EFI 4.6. touchy subject for some  Both can make excellent power. My experience is all in the 302's. Never owned a 4.6 so i may be a bit biased. The 302 is a high torquing, low end motor. But the 4.6 can produce some real nice power from what i've seen. Biggest difference is how u get the power and how much u spend. Getting the power from the 302 with carb, would be cheaper IMO. Not to mention the availability of parts is tremendous. You would have to either change your pump, or put an adjustable regulator on it. However if its gonna be a daily driver, you can't beat EFI. The amount of work to put the 4.6 in will be high also. "Know how" is more important for a carb'd engine imo also, tuning wise.
07-19-2009, 01:07 AM
#3 | | Legacy Member
Drop the 302 in.
__________________ I like turtles. |
07-19-2009, 07:41 AM
#4 | | Registered User
Thanks to both Otlaw80 and to MarkuzLS1. Got to figure out how much more work I want to do. LOL
07-19-2009, 09:40 AM
#5 | | Registered User
The 4.6L would probably be easier to swap in than the older 5.0. For the 4.6L, you probably just need wiring, ecu, a few misc. parts and possibly change the motor mounts, and some misc. tuning. Either way you're going to want to upgrade the rearend to handle the extra load taken on from the new engine. May want to try and get an 8.8inch out of the car as well and get a rebuild kit for the tlok/gears.
As Outlaw80 said, the 5.0 would probably be the better engine for serious horsepower. But as he also stated, if it's a daily driver, the 4.6L is probably the better choice.
07-19-2009, 10:17 AM
#6 | | Terminator Owner
a 302 has much more per dollar potential than the 4.6 even though the 4.6 is gaining ... its not quite there yet.
__________________ 2003 Cobra Vert (Redfire) #3938 of 5082 @ 05/27/2003
472rwhp/493rwtq - Modification List - Dyno Sheet 2012 Mustang 3.7L M6 (Kona Blue) 2011 Ford Edge Sport (Red Metallic) |
07-19-2009, 10:40 AM
#7 | | Registered User
Thanks much for the info guys. I think one of my problems is that I want a daily driver and the horsepower. LOL. May go ahead with the 4.6 for the convertible and look for another to build for the 5.0 HO and just sell the Crown Vic as is. Thanks again.
07-19-2009, 11:03 AM
#8 | | Registered User
Yah, try and find a real cheap 4 cylinder fox with a decent frame and put the 5.0 in that. It'd make a nice project car.
You could do a pi swap on the 4.6L, a few smaller mods and a good tune to gain more horsepower and still be a good dd.
07-19-2009, 01:48 PM
#9 | | Registered User
Thanks Sonic. This may sound really stupid, but what is a pi swap? Sorry, new at this game.
07-19-2009, 02:01 PM
#10 | | Legacy Member
| Re: Which engine to use :-) Quote:
Originally Posted by Babydoll Thanks Sonic. This may sound really stupid, but what is a pi swap? Sorry, new at this game. | PI refers to the heads of the 4.6. In 99 Ford started using PI (I believe "port improved?") heads which flow a lot better than the non-PI heads, and thus give a lot more power. If you're looking at doing a heads swap, but don't want to spend the money on real nice heads, you can't go wrong with starting out with the PI heads. Or, Trickflow has just released brand new heads for the 2v that with a decent set of cams will set you between 350-375 rwhp.
__________________ SOLD! 2002 Sonic Blue GT, 5 Speed
07-19-2009, 02:15 PM
#11 | | Registered User
Originally Posted by Babydoll Thanks Sonic. This may sound really stupid, but what is a pi swap? Sorry, new at this game. | Oh no, no problem at all, if anything, I'm the idiot for not explaining it in the first place. jimmy_beaner did a nice job explaining it, do thank him...
07-19-2009, 02:18 PM
#12 | | Legacy Member
Originally Posted by sonicpony03 Oh no, no problem at all, if anything, I'm the idiot for not explaining it in the first place. jimmy_beaner did a nice job explaining it, do thank him... | Yes... do  Don't waste your time buying ported PI heads... as the cost will be comparable to the new Trickflows, and the TFS heads will outflow the ported PI heads UNported.
07-19-2009, 03:48 PM
#13 | | Registered User
Thanks to both of you -- Sonic and jimmy_beaner. The boy that wrecked the 97 had the 4.6 rebuilt and some modifications done. The only things that I know for sure are that it is bored 20 over and the timing gears are not stock any longer. Not sure about the cams or the heads. Most of the paperwork on the rebuild got left in the glove box of the car and the guy I bought it from let it get soaking wet. The engine only has 9400 miles on it but the body is totalled.
07-19-2009, 04:01 PM
#14 | | Legacy Member
Originally Posted by Babydoll Thanks to both of you -- Sonic and jimmy_beaner. The boy that wrecked the 97 had the 4.6 rebuilt and some modifications done. The only things that I know for sure are that it is bored 20 over and the timing gears are not stock any longer. Not sure about the cams or the heads. Most of the paperwork on the rebuild got left in the glove box of the car and the guy I bought it from let it get soaking wet. The engine only has 9400 miles on it but the body is totalled. | That motor is probably your best bet. Also, you know where the Thanks! button is hahaha.
07-19-2009, 09:16 PM
#15 | | Registered User
Yah, as long as the engine's solid...I'd go for it...the difference from that 3.8 will be like night and day.
07-20-2009, 04:37 AM
#16 | | Registered User
I was actually looking for the Thanks button at the bottom of both of your messages, but it is not there. Am I missing something or not doing something right?
07-20-2009, 07:50 AM
#17 | | Registered User
Originally Posted by jimmy_beaner That motor is probably your best bet. Also, you know where the Thanks! button is hahaha. | You thanking whore!
07-20-2009, 08:05 AM
#18 | | Legacy Member
Originally Posted by Babydoll I was actually looking for the Thanks button at the bottom of both of your messages, but it is not there. Am I missing something or not doing something right? | Idk.. it should be Quote:
07-21-2009, 12:44 AM
#19 | | Registered User
Hm jimmy, I don't see it either.
__________________ Quote:
Originally Posted by MetallicMist OsirisGuy is correct | Quote:
Originally Posted by stangaroo OsirisGuy is right | 2002 Mustang GT
07-21-2009, 12:48 AM
#20 | | Registered User
i heard somewhere that once labeled a thanks whore you can only get so many a week... :dunno:
and yes, this will be another forum were jimmy is basically the only unthanked person it in...
It's cheaper to be beat a viper than to lose in one. 1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs). Quote: |
Originally Posted by sti2gsxr There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles. | |
07-21-2009, 04:22 AM
#21 | | Legacy Member
Originally Posted by bloodyspirit058 i heard somewhere that once labeled a thanks whore you can only get so many a week... :dunno:
and yes, this will be another forum were jimmy is basically the only unthanked person it in... | perhaps I will have to talk to Brent about it. All I said is "you know where the Thanks button is"... if someone wants to say thanks... that's what the feature is for  ... perhaps I'm missing the point of the feature.
07-21-2009, 10:38 AM
#22 | | Registered User
just giving you a hard time  and yes, that is what the feature is for
07-22-2009, 06:39 PM
#23 | | Registered User
Originally Posted by sonicpony03 The 4.6L would probably be easier to swap in than the older 5.0. For the 4.6L, you probably just need wiring, ecu, a few misc. parts and possibly change the motor mounts, and some misc. tuning. Either way you're going to want to upgrade the rearend to handle the extra load taken on from the new engine. May want to try and get an 8.8inch out of the car as well and get a rebuild kit for the tlok/gears.
As Outlaw80 said, the 5.0 would probably be the better engine for serious horsepower. But as he also stated, if it's a daily driver, the 4.6L is probably the better choice. | But didnt 94 gts come with 5.0s?
2000 silver 3.8 5 speed,smoke tint,cold air intake,MAC Long tubes, MAC Catted H,MAC GT catback, SCT Livewire w/ Bamachips tune,
17x8Fr 17x9Rr Bullit Wheels More to come......
96 honda magna vf750, K&N, Vance and Hines pipes Rejetted carbs
07-22-2009, 06:43 PM
#24 | | Registered User
Originally Posted by jimmy_beaner PI refers to the heads of the 4.6. In 99 Ford started using PI (I believe "port improved?") | Hmmm I've heard it was power improvement
07-22-2009, 06:54 PM
#25 | | Registered User
Originally Posted by Ninethourpm But didnt 94 gts come with 5.0s? | Yah the 94 and 95's came with the 5.0's, but I think the mustang GT he found was a 97, so it would have the 4.6L. Idk how different the 88 crown vic's 302 is from the 94-95 302. I just figured it'd be easier to use the 4.6L since it's going to be a dd.
07-22-2009, 06:58 PM
#26 | | Registered User
Either way hes in for a project.
07-22-2009, 07:12 PM
#27 | | Registered User
yes sir
