Sway bars... - Mustang Evolution
Old 04-17-2005, 08:49 PM   #1
232stang01's Avatar
Send a message via AIM to 232stang01 Send a message via Yahoo to 232stang01
Smile Sway bars...
Since I got the GT rear sway bar in, I've been wondering how adversly a heavier front bar would affect my handling. Any thoughts on that, or suggestions as to which way to go with it? I've decided that my main fucus for the next few months is going to be handling, and after new tires, subframes are next.
Any help would be great.
232stang01 is offline   Reply With Quote
Old 04-17-2005, 09:54 PM   #2
fastmustangs1's Avatar
Talking
I also originally installed a rear GT bar on my V6. It oversteered bad so I put on the GT front and it solved the problem. If you have a bigger bar on either the front or back the car will oversteer or understeer. Oversteer will seem like the back wants to spin on you coming into the corners, were as understeer is case in which coming into a corner and the car doesn't want to turn so the feeling is the car still wants to remain straight.
Good Luck,
Matt
Name:	100_0516 copy 2.jpg
fastmustangs1 is offline   Reply With Quote
Old 04-17-2005, 10:19 PM   #3
what year gt did it come off of, if its like 24mm sway bar definitly get a new front bar, if its 21mm you will be fine with just the rear.
Old 04-17-2005, 10:29 PM   #4
Thumbs up
Same year as my car 2001. What other suspension mods do you have.
Matt
Old 04-17-2005, 10:30 PM   #5
Yes I believe the Gt front sway bar is 26mm.
Matt
sway bars? greekstang Pre-2005 V6 Mustang 22 01-24-2006 09:48 AM
Last year for rear sway bars on V6 Mustangs? Brent Pre-2005 V6 Mustang 9 05-19-2004 11:30 AM
running skinnies and no sway bars tire The Bar 2 03-05-2004 11:39 AM
sway bars part2 JoeR. Pre-2005 V6 Mustang 10 01-05-2004 11:37 AM
Sway bars JoeR. Pre-2005 V6 Mustang 26 01-05-2004 10:49 AM
01:54 AM
