tick in new motor? - Mustang Evolution
Old 04-18-2005, 08:57 PM   #1
Send a message via AIM to hoof
tick in new motor?
I just put a 99 motor in my '98 convertible, and I have a tick in the oil pan. It sounds like something hitting the crank. I think I used the 98 oil pan on the 99 motor so maybe that is the problem, I really don't want to pull the motor to check itout.
CHAZ
hoof is offline   Reply With Quote
Old 04-20-2005, 01:58 PM   #2
RGR
Send a message via AIM to RGR
Is that a 4.2 you got? If so, you need to check the oil pickup tube clearance
cuz it will hit the rods if it is not bent outward from the rods. Stop driving it
and chek that out! If you lose oil pressure you can lose the whole motor.
It's an easy fix but you may need a new tube...
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 04-20-2005, 02:59 PM   #3
No I don't think its a 4.2
Old 04-20-2005, 04:45 PM   #4
a continuous tick that increases/decreases with rpms, or does it do it a little bit then stop or what not?
Old 04-20-2005, 07:04 PM   #5
RGR
ah, I think I remember now, Hoof got that new shiny SSM shortblock and went
SPI swap at the same time
Rob had that oil tube problem when he went to a 4.2 in his car...
sounds just like what he had. It could be the tube, even on a
3.8 it could be installed off a bit or get tweaked just enough
to cause a collision with a rod. Plus he said it was an oil pan tick.
Old 04-26-2005, 09:01 PM   #6
I didn't realize that I had a thread going here. I solved my tick problem, the windage tray was bent. It must have either happened in shipping, or when I put the pan on. I talked to Tom Y. and he told me to just toss the windage tray. I had a he!! of a time getting the pan off without pulling the motor. I had to lower the k-member, and then jack the motor up, but it came off. Now I have a little oil coming from the pan, but that is to be expected trying to seal that pan up while laying on a creeper. I did have the wrong oil dipstick tube on, but that was just giving me a false oil level, not affecting the noise.
CHAZ
Old 04-27-2005, 06:09 AM   #7
slvr2000stang's Avatar
Good to hear you got it solved.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 12:03 AM
new motor rswan112 Pre-2005 V6 Mustang 3 03-06-2007 09:50 AM
What motor.. bullitt482 General Car Discussion 55 02-23-2007 03:51 AM
New Motor GT-Eater Pre-2005 V6 Mustang 30 07-18-2005 12:01 AM
Motor coolstang Pre-2005 V6 Mustang 5 01-21-2005 09:19 AM
11:29 AM
