Exhaust Help! - Mustang Evolution
Old 07-21-2009, 11:36 PM   #1
2007STANG's Avatar
Region: West Virgina
Exhaust Help!
Ok just install Dule Exhausts 304 Stainless i've broken off two ring style clamps and there still not tight tryed to put never seeze on them and can't get them tight any ideas
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
2007STANG is offline   Reply With Quote
Old 07-21-2009, 11:39 PM   #2
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: Exhaust Help!
isn't it like 1 in the morning there? i'm guessing by ring style clamps you mean those metal band ones you can use a screw driver to tighten? i've broken some of those b4... you just need to get higher quality ones, i hate tightening cheap ones and having them strip apart cause they are crappy metal.
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 07-21-2009, 11:44 PM   #3
2007STANG's Avatar
Re: Exhaust Help!
these are real heavy clamps i tighten them down with an impack wrench at 100 psi and still didn't tighten enough to keep them from moving so i took to a repair shop and they tighten them to the point of breaking and still didn't tighten up (installed last 24hr) 9/16 nut
Old 07-21-2009, 11:53 PM   #4
Region: Oregon
Re: Exhaust Help!
i think i'm missing how these are installed and what they are holding...
Old 07-21-2009, 11:58 PM   #5
2007STANG's Avatar
Re: Exhaust Help!
2 1/2" 304 SS the clamps look like 2 rings with a 9/16" nut that you tighten up and it closes the two rings together (the main thing is the stainless is hard to crimp together)
exhaust
10:31 PM
