So tell me how Nitrous is sprayed with an auto - Mustang Evolution
Old 04-21-2005, 03:57 PM   #1
I know you have a WOT that sprays your engine when you are at wide open throttle... but does it spray in first, second, third and fourth gear??? What rpms... do you set what rpm it sprays at?
How does a tune work with this? Can you flip the switch on the fly if you want to spray or do you have to turn the car off flip the switch and crank it back up?
Just wondering how this all works because I am looking at it once I get my engine put in
Old 04-21-2005, 04:00 PM   #2
Zim
You want to **** me?
Zim's Avatar
Youve got the WOT switch, and then another "arm" switch. Basically, since you have an auto you wont need a window switch, so you have full control of when you turn it on. In first gear as long as your at WOT, you just flip the arm switch on at a certain RPM, and itll start spraying till you either let off the gas, or turn the switch off. I always spray at 3k in first gear and just let it go till im done with whatever Im doing. You dont want to spray in O/D gear though since its so weak...
I like toys
Old 04-21-2005, 04:02 PM   #3
So what about the chip and tune?
Old 04-21-2005, 04:15 PM   #4
[hijack] What about with a 5 spd. How does that work [/hijack]
Old 04-21-2005, 04:18 PM   #5
timpryor's Avatar
*cough*turbo*cough
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 04-21-2005, 04:21 PM   #6
Originally Posted by timpryor
*cough*turbo*cough
No need for that when a 150 shot will get me close to 11's
Old 04-21-2005, 04:23 PM   #7
If he was wondering about turbos, Brent is smart enough to ask about turbos. Since he is wondering about nitrous, he asked about nitrous. Go take a cough drop and quit cluttering up the tech boards with useless, annoying posts.
Also with the nitrous, how much does a bottle fill usually run?
Old 04-21-2005, 04:54 PM   #8
bluemustang's Avatar
The way the WOT works is it sprays once you have that window switch armed. If its not flipped nothing is spraying. This is where the rpm window switch comes to play. The pills you put in is where it will spray IE me i had the 3000 rpm - 6000 rpm pills. when armed (you can throw it in for off the line or once into 1st gear) it sprays exactly at 3000 rpms and end right before it shifts (thats the biggie spray must end before shift)
As for the tune at the time Jerry from Fordchip tuned it using a flipchip. One setting was for "normal" no nitrous, and when I feel the need to use the nitrous a simple flip of the toggle and it goes over to setting for nitrous (advanced timing and etc) and yes it works as easy as flip last second type of deal.
Also as for how long a bottle lasts all depends how much of a shot your using the higger the shot the quicker the tanks empties. Usually lasts about 10 uses depending how long you use the shot too.
Old 04-21-2005, 04:55 PM   #9
Nitrous is the ish
75 shot had me low 13s and just bolt ons w/ traction issues too i was knocking on twelves on a relativly stock motor :yup:
Old 04-21-2005, 05:43 PM   #10
Thanks for the input... Nitrous is the way I am going
Old 04-21-2005, 06:31 PM   #11
So does this all basically apply to 5spds as well?
Old 04-21-2005, 10:16 PM   #12
Im presuming it could be. I think it be better for a push button on 5 spd considering your in control of shifting.
Old 04-21-2005, 10:18 PM   #13
Yeah trust me once you go juice your gonna get addicted :yup:
Old 04-21-2005, 10:23 PM   #14
Monkey's Avatar
Everything You Wanted to Know About Nitrous
Old 04-21-2005, 10:49 PM   #15
so if i were to do nitrous on a 5spd. I would use a go baby go button?? Will I get thrown in my seat and vision blurred???
Old 04-21-2005, 11:33 PM   #16
Thomas91169's Avatar
brent on a auto nitrous is great cause it will just keep spraying throughout the whole run. on a manual if you have a wot switch itll automatically turn off the nitrous when you let your foot off the gas, cause, though im not 100% correct, using nitrous at a 0throttle, idle or deceleration is very bad. and if youre using a "fast and furious" type of switch(button on wheel, etc) you should take your finger off the button during shifts.
as for tune, you need to look into a chip that lets you switch between 2 or more specific tunes. one for daily(good mileage one) one for race w/o nitrous and one for race w/nitrous. i remember back when i was looking into modding the tbird some place made a 2 part tuning chip, one street, and one track, that had a toggle you mount to switch between the two.
if you do a single tune with nitrous the only drawback is when you go wot without nitrous you will be running very rich. cause with nitrous as you should know, you must add more fuel to compensate.
-Thomas-
Old 04-22-2005, 10:06 PM   #17
Monkey's Avatar
You don't need a tune for an occasional 100 shot and for 75 shot. Just run the highest pump octane you can get (93 usually) and get one heat range cooler spark plugs (autolite 764s). You only need a tune or a flip switch if you have timing advanced and need the other setting to ****** timing during nitrous usage.
Old 04-22-2005, 10:07 PM   #18
Well I would need a flip switch then especially with my new engine
Old 04-22-2005, 10:30 PM   #19
Monkey's Avatar
tell me about your new engine. I know you sent me the specs, but I am not on my computer and I forgot them.
Old 04-22-2005, 10:37 PM   #20
What I have paid for so far:
4.2L Rotating Assembly
224/230 Cam
Forged I-Beam Rods
Forged Pistons
Stage 3 Heads w/ High Lift Conical Springs and 3-Angle Valve Job
Stage 3 Lower Intake
Stage 3 Upper Intake
New bearings for the cam and crank
Every Gasket I will need for the swap
What remains to be bought:
Pay for the block to be machined .030 over and balanced etc
New Battery
New Rear Main Seal
New Spark Plugs
New Spark Plug Wires
19# Injectors
255lph Fuel Pump
New Radiator Hose
Chip Reburn
And then she will be ready to go in the car
My Current Mods are Tranny Cooler, 8.8 w/ 4.10 Gears, Chip
Old 04-22-2005, 10:48 PM   #21
Monkey's Avatar
you will forever have to run 93 octane with that motor. gonna be a beast though.
But yes, you will need a flip chip. Run as much timing as possible with 93 in the car on one setting. That will keep you N/A strong. On the other setting, ****** the timing just enough for whatever shot of nitrous you are going to spray. You will need to know how much you want to run. You can always go down, but i would highly recommend not increasing the size after tuning. I would do a 100 shot with those mods. So you will prolly need to pull about 3-4* out of timing and still run 93 in there.
About your previous post -- Yes and no about turning a car off to change the settings. When I got rid of my car there were two big chip people. Fordchip (whoever they became) and Diablo. Pete made you turn your car off to change. Diablo was working with a flip chip design where you would have to slow down to under 5mph (so a stop light would be ideal) to flip it. I don't know if it ever got off the ground and/or works, but it is a possibility. But for now, you have to turn your car off to change settings.
P.S. -- once that engine is good to go -- but a new 2800 PI Stallion torque converter. best mod for autos -- better than 4.10s
Old 04-22-2005, 11:20 PM   #22
Thanks for the help
Old 04-23-2005, 05:14 AM   #23
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
i wish i had more money
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 04-23-2005, 05:13 PM   #24
I had Jerry from at the time Fordchip now SCT and the flipchip was flipable as long as your not going fast. it worked just fine. And for whomever said a tune isnt needed gotta disagree a tune is needed. I ran the nitrous one time with just 94 (gotta love Sunoco) and it wasnt pulling as hard across the band as till after Jerry did up the tune. Man after the tune it was a literal night and day difference.
Old 04-24-2005, 11:22 AM   #25
you got to spray though a gear shift in an auto? that cant be to great for the motor can it?
You need a 5 speed..... best listen to me now than a year from now when you are sitting there and you go s*** you were right I should have got a manual!
Old 04-24-2005, 01:34 PM   #26
Oh no way thats the worst thing to ever do. You want the window switch to end the spray before you shift. aka once you get tuned see where your shift points are so you can get the right pills.
Old 04-24-2005, 08:24 PM   #27
Oh. My. God.
I am not getting a manual
nitrous
nitrous upton7 1996-2004 Mustang GT 1 05-02-2009 08:52 AM
Sprayed in bedliner and billet fuel door with lock... Rick0636 The Bar 21 08-06-2005 12:42 PM
Nitrous Express wet nitrous kit Zim Mustang Parts for Sale and Wanted 24 06-15-2005 01:43 PM
nitrous and a auto cuban3jumper Pre-2005 V6 Mustang 5 07-02-2004 07:53 PM
06:23 AM
