Aggressive camber - Mustang Evolution
Old 08-07-2003, 01:31 AM   #1
Send a message via AIM to ASSEMbler
Aggressive camber
I was wondering what's the most aggressive camber you've seen ?
ASSEMbler is offline   Reply With Quote
Old 08-07-2003, 10:43 AM   #2
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I talked to a guy who had 1.6* of negative camber on his 98 mustang. Does that count?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 08-07-2003, 10:57 AM   #3
Rick0636's Avatar
That kind of camber will cause serious tire wear problems I am sure.
Old 08-07-2003, 11:43 AM   #4
tire's Avatar
Send a message via AIM to tire
haha 1.6 isn't horrible. tire wear will indeed happen faster than usual but it shouldn't crap out for a while. an autoxing friend of mine run a full 2 deg. and his near stock C spring lowered V6 came in recently .3 sec behind 99+ Cobra.
tire is offline   Reply With Quote
Old 08-11-2003, 08:56 AM   #5
Region: Iowa
Camber owns me Brent Pictures and Videos 13 09-13-2006 08:34 PM
Wheel Camber? Ibanezplayer272 Mustang Audio & Video 6 05-05-2006 08:12 AM
Camber Kit ??? fastang11 Pre-2005 V6 Mustang 21 04-03-2006 11:25 AM
Camber Kits ??? fastang11 Pre-2005 V6 Mustang 6 02-16-2006 03:16 PM
What is the most aggressive gear I can go with? ASSEMbler Pre-2005 V6 Mustang 26 07-27-2003 05:21 PM
11:11 AM
