wierd noise ??? - Mustang Evolution
Old 07-23-2009, 10:45 PM   #1
yoshiStang19's Avatar
Question wierd noise ???
ok i need i help guys plz !!
i just noticed todat that theres a weird dinging sound almost like a whislte maybe coming from the engine.
idk what it is i dont kno **** about cars lol,but it seems to want to die when i rev it a lil and when the rpms come down it goes dn past 1 and then like stahls like wanting to die....
what could it be?
ima have to say its comming from the back end of the motor
yoshiStang19 is offline   Reply With Quote
Old 07-23-2009, 11:17 PM   #2
upton7's Avatar
Re: wierd noise ???
you don't have cat-converters do you?
Old 07-24-2009, 01:27 AM   #3
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: wierd noise ???
vacuum leak... tps... maf... the other little air thingy i can't remember the name of but f's everything up... just a couple of stuff to check, because of the whistle i would say look for vacuum leaks and/or cracked hoses.
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 07-24-2009, 08:38 AM   #4
Re: wierd noise ???
no i dont have cat converters.
and now lastnight i checked the plugs and the last plug to the rear was loose
so i took the air intake off the throttle body i believe,and unplugged the plug loosened it up a lil more and then put it back in tighter....ok put everything back together started it seemed much better......untill i reved it a lil...and now its a crack noise like......
crack crack crack (rev) CRACKLING CRACK CRACK crack.....lol
idk if has any thing to do w the plug or what?
Old 07-24-2009, 09:17 AM   #5
Region: Oregon
Re: wierd noise ???
like a breaking stick type crack? or like a metal rattle? is it noticeable enough to maybe record it? look at the plug again and make sure you didn't use the wrong ones and just smashed that plug with your cylinder... only thing i can think of right now
Old 07-24-2009, 10:02 AM   #6
Re: wierd noise ???
idk im not sure how to describe it
n yeah i did record it i have it right here next to me but,lol its ma gfs camera so i dont have the usb see if i can do it here in a min ...but yeah its noticable all kinds i can hear it when im driving
Old 07-24-2009, 10:36 AM   #7
Re: wierd noise ???
ok the vids r being uploaded right now its just taking a while.....ima put up on youtube and then link them here
Old 07-24-2009, 11:05 AM   #8
Re: wierd noise ???
there it is
Old 07-24-2009, 04:31 PM   #9
Region: Oregon
Re: wierd noise ???
uh... don't know what to say... sry... to me that sound very odd as a v6... not trying to be mean, but it sounds like a beefy lawn mower. does it ever die after you rev it? it sounded like it was dipping kinda low when it came back down, but than you zoomed out and it seemed to be idling fine... :dunno: i'm sure someone will be by with better advice/questions
not sure if i hear it or not, but are you hearing a metal "meshing/clacking" noise... it might be valve noise, i know my protege has really bad valve noise, but it also has 200k on it...
Old 07-24-2009, 06:41 PM   #10
Re: wierd noise ???
Is the check engine light on? If so, take it to auto zone, advance, etc and let them plug up their obdII to check it out, it's free.
19Delta is offline   Reply With Quote
Old 07-25-2009, 12:25 AM   #11
Re: wierd noise ???
well idk if yall can hear it like i do on the vid ...its like cracking and/popping idk its just hard to explain...if n e thing ima have it looked at prob next next week cuz this monday im getting body and paint on it...but i wana have an idea if its going to be costy you kno.
Old 08-01-2009, 01:01 AM   #12
Re: wierd noise ???
think it might be the header gaskets maybe?
is it hard to replace em?
n e body got n e vids on how to do it?
Old 08-01-2009, 01:42 PM   #13
2007STANG's Avatar
Region: West Virgina
Re: wierd noise ???
sounds like an exhaust manifold or head gasket is there and oil in the radaitor or water in the exhaust
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
2007STANG is offline   Reply With Quote
Old 08-01-2009, 03:44 PM   #14
Re: wierd noise ???
Jesus Christ people.
Check the midpipe flange on the passenger manifold, the a/c drips on that flange and causes the weld to break, hence making the exhuast disconnect. You will either need to have someone weld that one back together or buy another one, or buy a set of headers.
This is a very very common problem with 99-04 V6 mustangs.
Old 08-01-2009, 04:45 PM   #15
2007STANG's Avatar
Re: wierd noise ???
sorry we will bow to your opinion from now on we were trying to help
Old 08-01-2009, 06:19 PM   #16
Re: wierd noise ???
Lol...wasn't trying to be degrading, just a common problem in the V6 community. I drove a V6 for 6 years and mine did it with less than 40k on the odo. The only way to truly prevent it is to go with a set of aftermarket headers.
Between trying to decipher the OP's post and watching the vid it just kinda popped out to me.
Old 08-03-2009, 11:43 PM   #17
Re: wierd noise ???
whoa whoa lol...ok well i got this guy replacing the gaskets on the headers after its out of the body shop...ima pay him 70 bucks to do it plus gaskets.....since i dont kno how =/
and if that noise keeps going on well then time to lok further into it.
Old 08-04-2009, 07:52 AM   #18
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: wierd noise ???
Checking the manifolds for cracks or signs of exhaust leak is something you can do yourself rather quickly. I agree with Lowflyn on that being the source of the noise. Check that first before you get a set of gaskets, to then have to get another set and pay even more labor if its the manifold itself.
DarkShadow is offline   Reply With Quote
Old 08-05-2009, 04:37 AM   #19
Tape's Avatar
Re: wierd noise ???
exhaust leak
Tape is offline   Reply With Quote
Old 08-05-2009, 08:39 AM   #20
Re: wierd noise ???
yea the ac drips on it, my 01 never had issue but I never really ran the ac~ its a cheap fix
Old 08-05-2009, 03:36 PM   #21
Re: wierd noise ???
yeah...well heres a stupid question =/
how do i check for leaks ??
im not familiar w stuff like that lol sorry
ummm
wierd clank v6stang04 Pre-2005 V6 Mustang 2 10-10-2009 11:28 AM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
Wierd Noise SeadudeRXP Pre-2005 V6 Mustang 6 02-13-2006 02:55 PM
wierd noise InVaDeR Pre-2005 V6 Mustang 16 09-21-2004 05:31 PM
Wierd Noise badazzstang Pre-2005 V6 Mustang 3 12-11-2003 01:27 PM
12:49 AM
